WTB: 914 Gauge Set for /6 Conversion, Need tach, speedo, and triple gauge |
earossi |
Nov 20 2014, 07:45 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
I'm looking for a matched set of gauges for a /6 conversion we are working on. I need the 150 mph speedometer, a 911 tach with redline markings at 6700, and the "triple" gauge that houses oil temp, oil pressure, and fuel level. Gauges need to be in good functional and cosmetic condition. Would prefer gauges from the mid to late 80's , but will consider others as well.
Mark Henry |
Nov 20 2014, 09:12 PM
What engine? IIRC 3.2 needs a certain tach. Not 100% sure as I'm doing a 3.0 and most of the early stuff will work for me. Speedo must match the trans, if it's a 901 your /4 speedo will work fine, I believe some 915's are mechanical and some electronic, etc....
Make sure you're getting the right stuff. |
rnellums |
Nov 20 2014, 10:01 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
TimothyND on this site is in south bend and does great work. He should be able to modify and make the stock gauges work if that would interest you.
mepstein |
Nov 21 2014, 05:54 AM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tim does great work but for a 6 you'll want to change the redline on the tach so for me it made sense to buy a 6 tach rather than modify the 4. It will still go to Tim for an led upgrade.
timothy_nd28 |
Nov 21 2014, 10:23 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
(IMG:style_emoticons/default/agree.gif) I have no provisions for changing the silk screen redline on the face dial.
However, I do have a new project in the works. I'm in the process of duplicating these from scratch (with a modern tach drive). But sadly, this is a slow going project |
earossi |
Nov 21 2014, 10:47 AM
(IMG:style_emoticons/default/agree.gif) I have no provisions for changing the silk screen redline on the face dial. However, I do have a new project in the works. I'm in the process of duplicating these from scratch (with a modern tach drive). But sadly, this is a slow going project Tim, Please PM me with your contact info so that we can talk live. |
Lo-Fi Version | Time is now: 4th June 2024 - 02:45 PM |
