chassis reinforcement - where to start, have the guds, where to start? |
TravisNeff |
Feb 1 2005, 01:46 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I am planning to do some reinforcements to my tub. I have the rear trunk cleaned out of paint and seam sealer, plan is to stitch weld the rear, install the engman kit sitting in the garage and reinforce the front trunk area (after welding in the AC patch).
I started on the rear panel filling the trunk release button and filling the emblem holes, have my patches in place for antenna and side markers, but started a bit on the shock towers. Then I thought, that I'd better plan this out a little bit better. The car has the engine and tranny in place for the moment and will stay that way for at least a month or so (moving). Where and how should I start? have the car on jackstands, measurements, bracing (to hold the chassis in place while I do this) etc. I'd hate to be 3/4 done and realize I goofed and should have done it in another order. I also plan on reinforcing the rear suspension pickup points, but that will happen when the engine/tranny comes out. Gimme some thoughts.. I'll try to clean up some and take a few pics tonight so you can see what I am working with |
TravisNeff |
Feb 1 2005, 01:48 PM
Oh, I know a lot of the factory style stiffening kit is debatable. Is it worth getting the kit and using what's good or making up my own pieces? (and would love to hear some ideas on this too).
TravisNeff |
Feb 1 2005, 02:41 PM
I guess I am bored and ought to get some work done instead..
Anyhow In a perfect world I would have the tub stripped and everything measured first. Then I would start from there. However, engine is still in, car is still on the ground with suspension. If I was to tackle one section of the car at a time (let's say the rear trunk) is there anything I should specifically prepare first, besides the crude trunk measurements? Here are my areas that I am going to do Rear trunk area cabin front trunk area (engine bay area comes later/last) Where would you start and why? |
Jeroen |
Feb 1 2005, 02:45 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
here's some usefull threads for ya...
http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=15765 http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=16128 depending on your goals and aims, you might have to dig a little deeper than just stitchwelds... |
scotty b |
Feb 1 2005, 02:46 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Get the rockers off and the engine out first so you will know where rust repair needs to be done. Then start on the most structurally important repairs first ,longitudinal,floor pan, front trunk,hell hole,rear trunk. That's my method,if there are no serious repairs, start at one end and work towards the other. I have to or the ADD takes over (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
TravisNeff |
Feb 1 2005, 03:20 PM
Jeroen,
thanks for the links, and that is definately what I am going to do for the shock towers when the engine comes out. I am following along Eric Shea's thread on windshield uprights and Brant's race car thread for ideas. Also Racer Chris' rear outer trailing arm mount boxing trick From where Br@d stated which parts of the stiffening kit are good/bad, I can't really tell if he is stating which is good or which one is bad. It looks like the panels that go over the inner wheel well is bunk. Scotty, Hell hole and battery tray had surface rust which I ground off and POR'D last time the engine was out. Rockers, longs and floors are good. rear suspension pickup points are good, solid and rust free. The only rust areas that need work is the lower corners of the firewall where the sound pad was, those sections will need to be cut out and replaced - non structural. The next spot is the tunnel, have loose surface rust in there from a leaky MC. Seam sealer is out of the trunk, tar paper is out of the cabin floor. The MC area is flexy so a brace or laminating a piece of sheet metal over the area is needed. So far so good, no structural repairs are requried. I need to make up some door braces before I start on the engman kit and rear suspension points. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:15 AM |
