McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,008 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
(IMG:style_emoticons/default/dry.gif) Not in the snow (IMG:style_emoticons/default/dry.gif) But Cool! (IMG:style_emoticons/default/smile.gif)
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
I.ll help.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,089 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
For once, this isn't me... (IMG:style_emoticons/default/biggrin.gif)
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,953 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I may be able to help. 72, 1.7L with stock D-Jet. I just installed the MPS repair/tuning kit and haven't had a chance to "dial it in," but it's still running ok and I could do some before/after stuff. My CHT was replaced about a year ago and I put one of Brad's spacers on it earlier this year.
What are we trying to fix? CHT behavior or just find a better replacement? |
McMark |
eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
Me?
I have a '76 2.0L (weren't they all that year?) DJet that is a DD. Has nearly 30K on my rebuild. Send me a PM |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I run djet and at the present time is my only transportation, so it gets driven everyday. I too have noticed a large failure rate of chts in the last few years. Would love to see an alternative. Be more the glad to help out with this
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If you are willing to use an L-Jet system, I can put one on Betty's car. It definitely gets driven all the time.
McMark |
Cool, four testers should be sufficient to know if it's a good upgrade. (IMG:style_emoticons/default/boldblue.gif)
Thanks guys! |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,292 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Mark can you elaborate?
Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,536 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Mark,
You can send one my way if you want one more data point. My car gets about 150 to 200 miles a week added on the odometer. Marty |
McMark |
Mark can you elaborate? Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? Since I'm running MicroSquirt I can graph the readings. I was getting a bit of bucking, each time the reading jumped it would squirt a bunch of fuel. The first one stopped reading all together and just had high resistance, so the engine always thought it was cold. Thankfully I had my laptop with me so I just turned off the cold-start enrichment and ignored the sensor. The second failure was similar, but never got to the worst case scenario. It would buck occasionally - just a quick miss and then back to normal. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I've observed this with newer sensors as well.. The old ones seem to hold up much longer and to be much more stable.
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
WHAT?!?!? You mean chasing the TPS and vacuum leaks isn't the only thing that might be causing my D-jet to experience the mysterious buck n hesitate during the normal driving commute? (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif)
Very interested in seeing the outcome here. Been upgrading bits in the engine bay to help make my 914 a more reliable commuter (IMG:style_emoticons/default/beerchug.gif) |
Jake Raby |
Something else I noted with the stock CHT is the resolution is very notchy.. It may be unresponsive for 20-40 degrees of engine temperature differential, then all of a sudden it'll change. This makes it very difficult to build a MAP of engine temp values in regard to enrichment.
Lo-Fi Version | Time is now: 1st July 2025 - 02:40 PM |
