Increased stroke from stock 2.0L crank? |
VWTortuga336 |
Nov 29 2014, 01:41 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
I've been doing some research on grinding crankshaft journals for increased stroke. Specifically, I've got a (what appears to be) stock 2.0L crank. I'm completely rebuilding the engine and will be getting some work done (inspections at least) on the crank and figured if there was some performance to be gained, I'd go for it.
I'm sure this has been done, or at least discussed here before. Can anyone give me some details on what I should do? |
a few loose screws |
Nov 30 2014, 11:01 AM
Member Group: Members Posts: 168 Joined: 8-August 14 From: canada Member No.: 17,754 Region Association: None |
I cant say for sure but with the 2.0 having 50 mm rod journals it would seem that the factory basically made an offset ground crank out of the 66mm stroke, 55mm rod journal cranks from the 1.7 and 1.8's. The math makes sense. Did I get it right? Please correct me if I'm wrong.
PotterPorsche |
Nov 30 2014, 03:46 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Lo-Fi Version | Time is now: 9th June 2024 - 07:01 PM |
