| MikeInMunich |
Dec 4 2014, 03:52 PM
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Hi guys,
I just got sad news. My rebuilt (to) 2-liter engine with headers, free flow muffler, mega squirt fuel injection and MSD / Petronix ignition was just on the dyno today. 80 HP at the wheels. (IMG:style_emoticons/default/sad.gif) I reckon this means something like 100 coming from the engine (?)... Can you knowledgeable experts out there offer some thoughts on this please? The headers were from OBX, bought, by the way, before I knew they were a knock-off of Kerry Hunter's product. The valves were adjusted and plugs are new. I do not have leak down or compression numbers at the moment but assuming they are what they should be, what do you think his thing should be putting out? If we are under what you think it should be, do you have any suggestions? Is there a way to easily improve air intake? Thanks for your time! M.i.M. |
| mr2by4 |
Dec 4 2014, 03:54 PM
Member ![]() ![]() Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
What cam are you running?
| Mark Henry |
Dec 4 2014, 03:58 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The headers are the only thing you listed that would help make more power...and OBX sucks.
I'd expect about 110hp. |
| monkeyboy |
Dec 4 2014, 03:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
What were you expecting at the wheels?
Was the car tuned fully, or just run on a dyno? There may be more power to be had, but probably not a lot. |
| MikeInMunich |
Dec 4 2014, 04:15 PM
| MikeInMunich |
Dec 4 2014, 04:16 PM
| MikeInMunich |
Dec 4 2014, 04:17 PM
What were you expecting at the wheels? Was the car tuned fully, or just run on a dyno? There may be more power to be had, but probably not a lot. We were hoping for about 115. It was tuned, as far as I know. Just got the result and haven't gotten answers to questions yet. |
| MikeInMunich |
Dec 4 2014, 04:21 PM
Additional question of importance...
It measured just 80 at the wheels. Is an expectation of 100-115 as a test result measured at the wheels or is something like e.g. 25% added to the figure measured at the wheels to estimate what the engine is putting out? IOW, if one would expect 110 am I down 10 or 30? |
| neilca |
Dec 4 2014, 04:29 PM
Member ![]() ![]() Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 |
No one goes to the dyno and are surprised by how much more HP they have over their expectation. A very humbling experience.
| ChrisFoley |
Dec 4 2014, 04:40 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,016 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Drivetrain loss should be around 15%.
That means about 94hp at the flywheel in your case. I would not expect any more than 100hp based on your description. OTOH, you could have gotten 125 from the proper combination of parts in a 2056 build with stock FI. |
| Kansas 914 |
Dec 4 2014, 04:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Drivetrain loss should be around 15%. That means about 94hp at the flywheel in your case. I would not expect any more than 100hp based on your description. OTOH, you could have gotten 125 from the proper combination of parts in a 2056 build with stock FI. (IMG:style_emoticons/default/agree.gif) |
| JeffBowlsby |
Dec 4 2014, 06:03 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,130 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| Mike Bellis |
Dec 4 2014, 06:49 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Maybe it's metric horsepower? (IMG:style_emoticons/default/biggrin.gif)
| SirAndy |
Dec 4 2014, 08:22 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Drivetrain loss should be around 15%. That means about 94hp at the flywheel in your case. I would not expect any more than 100hp based on your description. OTOH, you could have gotten 125 from the proper combination of parts in a 2056 build with stock FI. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) For a stock rebuild with a stock cam, 80ish at the wheels sounds about right ... (IMG:style_emoticons/default/shades.gif) |
| DBCooper |
Dec 4 2014, 08:47 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Drivetrain loss should be around 15%. That means about 94hp at the flywheel in your case. I would not expect any more than 100hp based on your description. A couple of years ago I spoke with a Ford transmission engineer who also mentioned that 15 percent number (and a little better, actually) as a rule of thumb, but the interesting thing was him saying that was about half the energy that older drivetrains lost. He was pretty proud of that improvement, part of a company priority to improve fuel economy. I don't know about the 901 specifically but suspect it would be one of those older less-efficient transmissions, and if it is then his crank number might be a bit better than that. Car won't be any faster, of course, but maybe he'll feel better about it. |
| pisces914 |
Member ![]() ![]() Group: Members Posts: 62 Joined: 27-April 04 From: seattle, wa Member No.: 1,988 |
please remember that dyno results are relative to that dyno - you could use another dyno and get a very different result - make sure to use the same dyno as you tune - hope this helps
brad in seattle |
| Maltese Falcon |
Dec 4 2014, 11:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,129 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Hi guys, If we are under what you think it should be, do you have any suggestions? Is there a way to easily improve air intake? Thanks for your time! M.i.M. Mike, Some dynos yield higher #s than other dynos, for instance; the Dynojet 248c usually shows higher #s compared to the Mustang (brand) Dyno. Then there are uncorrected #s (higher) and corrected #s (lower). The location / altitude of the Dyno is important, like Denver vs. Long Beach. Your 2.0L with light mods seems just a tad low. Our 2.0 efi club racer makes less than 100hp, with limited mods, no headers. We do use a (allowed in class) high flow cone air filter .It does not make big hp but keeps the revs up between shifts and helps all around throttle response. Watch + hear it run at Willow short track, on the home page at Www.msdsinc.com Marty |
| Alphaogre |
Dec 4 2014, 11:53 PM
Member ![]() ![]() Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
| Bleyseng |
Dec 5 2014, 08:17 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
That's about right for a 2.0L with a stock cam.....
Here is my dyno chart from before I went with a Raby cam. Attached thumbnail(s) |
| eyesright |
Dec 5 2014, 08:36 AM
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
That's about right for a 2.0L with a stock cam..... Here is my dyno chart from before I went with a Raby cam. (Please excuse the blatant hijack. Enquiring minds want to know...) After? And which cam, P&C's? My "stock" 2.0 L FI with 9550 and flat top pistons FEELS nicely stronger. I'm very happy just having a well running car but having before and after numbers would have been intriguing. |
Lo-Fi Version | Time is now: 8th December 2025 - 07:59 PM |
