| EdwardBlume |
Dec 6 2014, 10:25 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
OK, I know its been discussed before.... so I'll ask again, for those of you who have done this....
What is the ideal engine for a /6 conversion? The ABM came with a 901.101.101. 7R From the Bruce Anderson book it would seem that normal engine HP for each possible engine is as follows: 2.4 w/ carbs - 130 ish 2.7 150 ish 3.0 170-180 ish 3.2 200 Before Andy jumps in, I don't want a 3.6 - too much power. (IMG:style_emoticons/default/lol-2.gif) What is the best driving /6 with ridiculous power? Is it worth it to build up the 2.4 to S spec? when you can get all the improvements of a 3.0? Thx |
| ConeDodger |
Dec 6 2014, 10:29 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Isn't Shea running an S spec motor?
I like my 3.2 in stock trim but I wouldn't call the power ridiculous... |
| SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Before Andy jumps in, I don't want a 3.6 - too much power Actually, if you look at my responses to that same question my answer has always been a 3.2 (with injection). It is all around the best engine choice for a street 914. (IMG:style_emoticons/default/smile.gif) |
| EdwardBlume |
Dec 6 2014, 10:32 AM
Isn't Shea running an S spec motor? I like my 3.2 in stock trim but I wouldn't call the power ridiculous... Is it drivable with good power on the mid to upper range? I used to have a 95 993 as a DD, and off the line, it was nothing special. I figure this is the only /6 I will ever have so I want to do it right. |
| EdwardBlume |
Dec 6 2014, 10:33 AM
Before Andy jumps in, I don't want a 3.6 - too much power Actually, if you look at my responses to that same question my answer has always been a 3.2 (with injection). It is all around the best engine choice for a street 914. (IMG:style_emoticons/default/smile.gif) So your 3.6 is for sale? (IMG:style_emoticons/default/shades.gif) From specs and evolution, the 3.2 is a winner, if you can find one. |
| rick 918-S |
Dec 6 2014, 10:35 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
From what I understand it's a fine line from the 2.7 to the 3.2. The 2.7 has fitment issues with the engine lid latch. The 3.2 will likely need oil cooling. 200 would be very nice though.
| campbellcj |
Dec 6 2014, 10:41 AM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,705 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
For a street car I say an injected 3.2 first choice, 3.0 second. I have a carbed 2.7 race engine in mine. Revs to 7800-8000, 230rwhp. I think it suits the character or the car better but is an expensive route and may not last as long despite the prep work and special parts.
| JStroud |
Dec 6 2014, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
It was a no brainer for me, my 2.7 was going to cost $7k just for machine work, I bought a 3.2 for $6.5k.
| PanelBilly |
Dec 6 2014, 10:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I think it's equally important to modify the tranny so you make use of the new power. Why have a first gear that you'll never use.
| EdwardBlume |
Dec 6 2014, 11:08 AM
| JStroud |
Dec 6 2014, 11:22 AM
Rob, I thought the ABM car came with a -6
| SLITS |
Dec 6 2014, 11:27 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
From what I understand it's a fine line from the 2.7 to the 3.2. The 2.7 has fitment issues with the engine lid latch. The 3.2 will likely need oil cooling. 200 would be very nice though. Only if you run with a CIS motor. Engine lid latch assembly will interfere with fuel distributor. Height of CIS engine is a problem with the engine lid if installed at the 7" height recommended by RJ and Maddog mounts. Drop it to 6.5" and it's no problem. Anything above 2.7 will require a modified flywheel or clutch assembly to run the stock 901 tranny with. 2.7L crank is 6 bolt and can accept the early 901 flywheel with the 215 mm stock clutch. You can run the stock 225 mm flywheel with a modified pressure plate and a 2 year only ('70-'71 911) friction disk. Has to do with the diameter and spline count required for the input shaft of the 901 tranny. 3.0 and above are 9 bolt flywheels. Anything 2.4L and above more than likely requires additional oil cooling (additional oil cooler). Don't have experience with anything below 2.4L. Anyway, that's a portion of my expeiences. |
| mepstein |
Dec 6 2014, 11:32 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I drove a 3.2. Started with one turn of the key after sitting for months. Had lots of power down low and near redline. Seller sold it out from under me to a euro who offered more money. so I bought a 3.2 engine on Pelican. Had extras like 964 cams, euro compression and custom SW chip. Can't wait to drive it.
| shoguneagle |
Dec 6 2014, 12:06 PM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
A lot depends on what you want to do with the car. If I were to build another, I would do the following:
Within Porsche - 3.2 for road traveling, dependability, conversion ease - 2.4 for peppy, road driving and handling with carbs - 2.7 ????? Subaru Sixer with transmission - for road traveling, dependability Chevrolet V8 - Downright right hot rodding, roadability, power, hadling (special modifications and weight saving items), specialized suspension, dry sump, aluminum heads, etc. Mucho dinero!! I have built both a V8 and Porsche Sixer (3.2). The V8 was built before Renegade and during Rod Simpson days. A lot of difference and parts/kits availability available then and now. Dry sump, suspension points raised, aluminum parts are available now and it could be a very expensive build to do it right. My 914 is being converted to 3.2 which I like very much. The conversion is fairly easy and straightforward with high marks for availability. Good engines and available parts are getting to the point where they are obsolete, supply availability getting limited, quality and dependability affected supply source, etc. When I started, this was the right build for me. The new Subaru Sixers are interesting and brings the conversion into a better supply source (present day and back). I do not know what the ease or costs are involved in this conversion but I would be looking at this combo with the transmission if I was building present day. Remember to allow sufficient time to get the project done. There are continuing hinders such as wife, thefts, moving, daily obligations, wife, just do not want to work on it, money, wife, etc. There have been conversions done here and one should do some research via the threads for better background info. It definitely is a fun project and will keep you "entertained". Best wishes and enjoy the project. Steve Hurt |
| EdwardBlume |
Dec 6 2014, 01:01 PM
| Mark Henry |
Dec 6 2014, 02:56 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Many ways to skin a cat, personally I like the 3.0, 3.2, 3.6 due to the superior aluminum case.
New (rebuilt) vs. used...new is expensive, but used is used so you want a known leakdown tested engine. 3.0 has better rods, CIS works but not the best system. 3.2 way better FI, but weaker rods. If you are changing the induction and rebuilding there are many options. |
| Series9 |
Dec 6 2014, 03:33 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Without ANY doubt: 3.2 with the stock FI.
230hp, the transaxle can handle it (if you don't do burnouts in 1st), and the first edition of digital FI on a /6 by Porsche (it's almost perfect). |
| EdwardBlume |
| Mueller |
Dec 6 2014, 03:44 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I really liked Scott Yeamans 3.0 liter /6 when I drove it many moons ago, narrow bodied car and I didn't think it needed more tire or power.
I've driven a few non-Porsche powered conversions and I really liked Fiids turbo Suby setup, I'd say it has about same HP level as Scotts 3.0. Just right for a street 914. |
| billh1963 |
Dec 6 2014, 03:48 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I'll be going with a 2.4...since that's what I have! (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 11:38 AM |
