> Subaru conversion help needed
post Dec 11 2014, 07:13 AM
914-6 GT in waiting
I'm bringing home a subaru svx in the next week or 2. Dropping it off at my mechanic to pull the engine. Besides the entire wire harness and ecu, what else should I pull from the car? Thanks, mark
4 Pages V  1 2 3 > »
Replies(1 - 19)
CptTripps
post Dec 11 2014, 07:44 AM
:: Punch and Pie ::
QUOTE(mepstein @ Dec 11 2014, 08:13 AM) *
Engine, Trans, any/all wiring, ECU....that's about all you CAN use.
There are a lot of guys that have used the dashboard and other stuff, but now you're getting pretty deep into custom stuff.
post Dec 11 2014, 08:19 AM
02 sensors off the exhaust. Don't know that engine but there may be 3. The factory wiring grommets are a huge benefit as well as all the relays that you can snag. You want the Big Block, huh? I've seen a bunch of smoking deals on smaller/lighter EZ30's in your area. Very popular in the northern climates.
Chris H.
post Dec 11 2014, 08:36 AM
QUOTE(mepstein @ Dec 11 2014, 07:13 AM) *
Welcome to the club! The "high value" stuff is mainly electronics. If the main door switch panel is good that is usually worth $60-$80. Get the cruise and trans modules (connected to the harness). If the stock radio is in there the SVX guys go NUTS for that. Don't bother with the trans for resale. I guarantee it will be crap. The lights and lenses have value if you want to make some $ back, and the wheels, side view mirrors as well. Not sure how far you want to go on the part-out. The front fenders are worth $ if they are Subie stamped. DO NOT BOTHER wrestling the gas tank out to retrieve the fuel pump. Flippin' PITA. PM me with questions.
post Dec 11 2014, 08:37 AM
914-6 GT in waiting
QUOTE(76-914 @ Dec 11 2014, 09:19 AM) *
$500 for the car. Already purchased. Thanks for info guys (IMG:style_emoticons/default/smile.gif)
CptTripps
post Dec 11 2014, 08:38 AM
:: Punch and Pie ::
QUOTE(Chris H. @ Dec 11 2014, 09:36 AM) *
Wise words! New ones are $100 and the one you pull will likely be crap anyway.
post Dec 11 2014, 08:40 AM
914-6 GT in waiting
Has a legacy trans but I'm not sure I will go to the trouble to part and sell. We'll see. Thanks
904svo
post Dec 11 2014, 09:02 AM
904SVO
Don' get rid of the car, you will find that you are missing parts when you do your
conversion. get rid of your donor after you get your car running.
effutuo101
post Dec 11 2014, 10:12 AM
And then sell it to a recycler.
post Dec 11 2014, 11:23 AM
914-6 GT in waiting
QUOTE(904svo @ Dec 11 2014, 10:02 AM) *
Good advise but I will not be able to keep the roller for long. So it's now or never.
d914
post Dec 11 2014, 11:24 AM
radiator mounts, misc nuts and bolts, strip it!!
mgp4591
post Dec 11 2014, 01:36 PM
I'm using the radiator out of my SVX in a lay-down slight angle configuration and it works. Fans and all fit, then run the hoses out the bottom plus saves me the trouble of getting new sheetmetal for my front trunk bottom- mines all bent up but solid. Does the fuel pump have to have the tank removed to get it or does it pull out from the floor like lots of other cars? My SVX runs strong, almost hard to part it out for donation but that's what I bought it for so my pump and running gear is good... it'll be good to share notes with someone else doing this at the same time!
904svo
post Dec 11 2014, 03:34 PM
904SVO
QUOTE(mgp4591 @ Dec 11 2014, 11:36 AM) *
The fuel pump and gas gauge sender can be removed thru the access panels
in the trunk. Don't forget the fuel pump controller mounted in the rear fender
well in the trunk.
Chris H.
post Dec 11 2014, 03:40 PM
Mine may have been hit, but I couldn't get all of it out easily without taking the tank out. The fuel pump has a bunch of parts to it. Can't hurt to try though.
Chris914n6
post Dec 11 2014, 11:34 PM
Jackstands are my life.
Don't know how much space you have and what you're paying you mechanic but glass, doors, door panels, hood, seats, console lid, shift handle,gauges, tcu, rear suspension to a mini trucker, sunroof, bumper covers, brake calipers, are all commonly damaged and craigslist sellable parts.
If it was me I'd gut the entire wire harness and everything attached to it. You can toss pieces later.
Take a gander at the svx classifieds to see what's hot and asked for. Might even make a friend there if you need specific help later.
mgp4591
post Dec 12 2014, 03:19 AM
QUOTE(Chris H. @ Dec 11 2014, 02:40 PM) *
I'd heard that it's not the first choice for transplanting into a 914 gas tank- not sure why though. If it's deep enough in the tank it can be made to fit with an adapter plate I'd think. I'm gonna pull it and see why not... (IMG:style_emoticons/default/idea.gif)
post Dec 12 2014, 10:16 AM
The impreza pump transplants well.
post Dec 12 2014, 02:22 PM
914-6 GT in waiting
QUOTE(Chris914n6 @ Dec 12 2014, 12:34 AM) *
He's pulling the engine for $100. He has a big lot and I definately will remove the entire harness but we'll see how far I get on the part out after the harness. Thanks for all the suggestions.
a914622
post Dec 13 2014, 10:12 AM
If the rear end is a 151? It's a limited slip and 200-300. The Datsun guys go nuts for those.
post Dec 14 2014, 04:01 PM
914-6 GT in waiting
It has a 4.44 Legacy Transmission. That's all I know.
Should I hold onto the inner cv's or are they different for a manual.
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 31st July 2025 - 05:06 PM
