Argh- PO used RTV between cam tower and head- now stuck |
tornik550 |
Dec 19 2014, 09:54 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I'm changing out my cylinder heads on my /6. For the most part the engine came apart quite easily. The engine looks to be in good condition. One huge problem is that it looks like whoever rebuilt this ing ine previously used a thin layer of RTV sealant between the cylinder heads and cam tower. I cannot separate the heads from the tower because of the damn RTV. I Would prefer not to damage the heads or tower however I could damage the heads if I have to since I am not reusing them. I removed the head/tower unit from the engine by undoing the head barrel nuts.
Any ideas how to remove the heads from the cam tower? |
r_towle |
Dec 19 2014, 10:01 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Map gas torch, melt the rtv
wndsnd |
Dec 19 2014, 10:13 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Use a soft mallet and tap around softly. It should not be that hard. Sometimes the dowel pins will stick.
John |
Luke M |
Dec 19 2014, 11:10 PM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
You have to seal the head to cam tower surface otherwise you will have a huge oil leak issue to deal with later. Usually case sealer is used to seal these surfaces but there was a rtv product around that some people used. I've always had to tap the heads off the towers. I would think that the dowel pins are probably a little stuck too and not just the rtv. Fyi just be careful not to hit the heads too hard to crack the cooling fins off. Also if you plan to split the case get a helper as it's a pain by yourself.
Lo-Fi Version | Time is now: 10th June 2024 - 05:19 AM |
