| drbill |
Jan 23 2015, 04:17 PM
Member ![]() ![]() Group: Members Posts: 58 Joined: 12-March 14 From: Fort Mill, SC Member No.: 17,110 Region Association: None |
1974 2.0 L, original D-jet FI. This car has become very difficult to start when cold. It almost wants to catch, but does not. After 15-20 tries, will finally start, then I need to keep feathering the throttle to keep it running. Once warmed up, it runs perfectly. It's been recently tuned up with valves adjusted, new plugs, wires, pertronix, timing set. Started better when weather warmer, but it is in a climate-controlled garage.
Tech tips says either the cold start valve or bad check valve in the fuel pump. Any other ideas? Thanks, Bill |
| 76-914 |
Jan 23 2015, 05:05 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,968 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
AAR valve, CHT sender
| Jeffs9146 |
Jan 23 2015, 07:46 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Lo-Fi Version | Time is now: 29th September 2026 - 09:32 PM |
