> Replacing oil gallery plug with 3/8 NPT oil temp sensor?
Geezer914
post Jan 25 2015, 08:45 AM
Geezer914
I am at the beginning stage of rebuilding my 1.8L to a 2056. I am prepping the block and replacing the oil gallery plugs with 3/8 NPT plugs. Would it be a good idea to replace one of the plugs by the oil filter housing with a oil temp sensor?
Replies(1 - 4)
Mark Henry
post Jan 25 2015, 09:05 AM
that's what I do!
QUOTE(Geezer914 @ Jan 25 2015, 09:45 AM) *
Better to use the taco plate.
SLITS
post Jan 25 2015, 09:16 AM
"This Utah shit is HARSH!"
1.) Is there sufficient room to install and wire it up?
2.) Will the probe interfere with oil flow in the gallery?
Since Porsche/VW never installed one in the location you wish to there had to be a reason.
Geezer914
post Jan 25 2015, 09:21 AM
Geezer914
I installed a Scat 1.5 qt deep sump kit with a oil temp sender installed and the temp gauge hardly moves.
Mark Henry
post Jan 25 2015, 09:32 AM
that's what I do!
QUOTE(Geezer914 @ Jan 25 2015, 10:21 AM) *
Wrong or faulty sender/gauge.
A quick base test is to bench wire it and put the sender in boiling water, at least that gives you a 212F (100C) mark.
There's a thread that McMark did about correct senders, it's likely in the classics.
- Lo-Fi Version Time is now: 3rd March 2026 - 05:31 PM
