got914? |
Member ![]() ![]() Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None ![]() |
Im newbie when it comes to porsche but wasnt the 4 speed a 930 transmission ?
I have a chance to get a 1983 4 speed from a 911 and just need some info. . |
MJHanna |
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 ![]() |
The 915 trans came in a 4 speed besides the 5 speed. Yes, 930 trans were 4 speed up until 87 or 88 when Porsche updated it with a 5 speed.
javadog |
Newbie ![]() Group: Members Posts: 20 Joined: 3-July 06 From: Tulsa, OK Member No.: 6,358 ![]() |
Im newbie when it comes to porsche but wasnt the 4 speed a 930 transmission ? I have a chance to get a 1983 4 speed from a 911 and just need some info. . You could get a 4 speed in a 911 for years, but not in 1983. If it is definitely from 1983, it's probably a 930 transmission, which is completely different from the 911 transmision of the same year. Posting the type number and serial number will let us tell you what it is. JR |
MJHanna |
first one is a 930
the second one is a 915 trans Attached image(s) ![]() ![]() |
got914? |
Im waiting on pics and numbers.
I know it came out of a turbo 3.3 if that helps any |
javadog |
Well, yeah, that helps. It's going to be a 930 gearbox. Not a good choice if you want to put it into a 914.
JR |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you are getting crazy you can use a 930 flipped upside down a'la 935, you have to cut out the trunk, figure out a linkage, mounts, etc.
A lot of engineering. Flipping the diff you have to remove too much material. But the whole box flipped upside down you could run the box as is, a 930 is a stout box for sure. Talk to Matt Monson if serious, he has researched this mod. |
TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 834 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
If you have a chance of a 930 gear box, it might be worth it just to flip it ( no Pun Intended) they are very hard to find and us V-8 guys dream of having one. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/welder.gif)
Let me know if it becomes available (IMG:style_emoticons/default/grouphug.gif) |
Mark Henry |
I don't know where you are finding these boxes, I'm imagining that you don't want to tell, but there is one porsche breaker in TO that I would not trust. He sells junk at gold prices. Smells like Nineafart. Also remember that a 930 may have seen a rough life.
If anyone is interested I can get you a fully rebuilt 930 box for $5K canadian, I think thats just over $4k US. Fully rebuilt with factory LSD, stock gears, new brake bands, dog teeth and slider on 3/4 the rest speced out good, new gasket set. I think you may know the builder (IMG:style_emoticons/default/wink.gif) |
got914? |
I know what ya mean about nineapart. They are the ones tharmt want 3 grand for a 915.
The possible 930 is almost a 7 hr drive but a good deal. |
Mark Henry |
I know what ya mean about nineapart. They are the ones tharmt want 3 grand for a 915. The possible 930 is almost a 7 hr drive but a good deal. The 930 will most likely need brake bands, dog teeth and slider on 3/4 gear, plus a gasket set you are talking over $1K US in parts. If 1/2 is gone as well the "good deal" case could cost you an extra $2K 930's wear out opposite of a 901 which wear out 1/2/3. There is no way to check this if (out of car) without cracking the case. Also not all 930's are factory LSD. If you want to change ratios, gear sets will cost you $1200 US each set from GBox or Albins. I know this because I've rebuilt and changed gears on a few. |
Lo-Fi Version | Time is now: 31st July 2025 - 05:10 PM |
