pgollender |
Member ![]() ![]() Group: Members Posts: 198 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California ![]() |
I also posted this in the Garage forum, but maybe more appropriate here:
![]() What fastener goes here between the two holes ? Threaded bolt with sleeve ? The space between tab and car frame is about 1-1/4 1-1/2 inches. |
Restorandy |
Newbie ![]() Group: Members Posts: 1 Joined: 5-July 20 From: Holly Springs Member No.: 24,459 Region Association: None ![]() |
Did you ever get the answer ? I have same question
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 601 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Bolt from inside front trunk, washer, lock washer nut. I think 10 or 12 mm. Pumpkin is a 70 also and I did not find a sleeve. Just pushed on it to get nut started and tighten.
Lo-Fi Version | Time is now: 9th May 2025 - 05:19 PM |
