| sdthomas |
Feb 13 2015, 02:26 PM
Member ![]() ![]() Group: Members Posts: 65 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest
I'm trying to remove my rocker panels to inspect and clean out the longs but can't get the cheesehead screws loose. I've sprayed them with PB Blaster every day for a week, to no avail. Any other tips?
Attached thumbnail(s) |
| bandjoey |
Feb 13 2015, 02:30 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Pb (IMG:style_emoticons/default/ar15.gif) blaster for 36 hours heat vice grips cursing and a screwdriver.
| moldygreg |
Feb 13 2015, 02:35 PM
Stay Golden ![]() ![]() Group: Members Posts: 136 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest
Pb (IMG:style_emoticons/default/ar15.gif) blaster for 36 hours heat vice grips cursing and a screwdriver. Yes to Vice grips. Soaking and patience. FWIW -- Have not had good luck with PB Blaster, but have GREAT luck with silikroil. (You can read the reviews on Amazon.com) For a couple very stubborn ones; ended up having to us some map gas which worked. One snapped, but it was easy to drill our and re-tap. It probably would not have snapped if I practiced my own words of soaking and patience. Good luck. |
| somd914 |
Feb 13 2015, 02:38 PM
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Pb (IMG:style_emoticons/default/ar15.gif) blaster for 36 hours heat vice grips cursing and a screwdriver. Agree with vice grips. Not sure if heating the vice grips will transfer enough heat - never heard of such, but interesting. Do you have new cheeseheads? 914Rubber sells stainless... Also, a few beers help (IMG:style_emoticons/default/beer3.gif) |
| ThePaintedMan |
Feb 13 2015, 03:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
If those fail, this always works for me on stuck screws.
http://www.harborfreight.com/impact-screwd...case-37530.html The torque it provides really helps. Just be VERY careful not to dent anything! |
| TheCabinetmaker |
Feb 13 2015, 03:29 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes on the impact screwdriver. No to harbor freight! Cheap bits break the first time you use them.
| budk |
Feb 13 2015, 03:40 PM
Yes! It's a Bumblebee! ![]() ![]() ![]() Group: Members Posts: 685 Joined: 24-July 10 From: Jasper, TN Member No.: 11,970 Region Association: MidAtlantic Region |
Pb (IMG:style_emoticons/default/ar15.gif) blaster for 36 hours heat vice grips cursing and a screwdriver. Agree with vice grips. Not sure if heating the vice grips will transfer enough heat - never heard of such, but interesting. Pretty sure he meant to put a few commas in there...... pb-blaster for 36 hours, heat, vice grips, cursing and a screwdriver. You can also try slightly tightening the screw before trying to back it out. if it moves a little both ways, keep treating it with blaster or silikroil |
| pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I had one stubborn one and it eventually broke off. Had to drill it out and re tap. Luckily it cleaned out OK.
Good Luck ! |
| sdthomas |
Feb 13 2015, 03:50 PM
Thanks for all the advice! What's the best way to apply heat? Blow torch? Heat gun? I really don't want to strip them.
| budk |
Feb 13 2015, 03:59 PM
| budk |
delete - duplicate
| rgalla9146 |
Feb 13 2015, 04:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
That screw looks to be in very good condition.
Because it is still "square" you can get a tight hold on it with a vise grip. Clean the teeth of the vise grip with a wire brush first. Work slowly, plenty of lube. That'll come right out. Those washers on the screw are original. |
| ThePaintedMan |
Feb 13 2015, 05:01 PM
Still think the impact screwdriver is worth a shot. Cheap and I guarantee you'll end up using it again. Much easier to get in there than vice grips and you won't risk burning the paint with flame. But all of the options mentioned have merit (IMG:style_emoticons/default/beerchug.gif)
| Cuda911 |
Feb 13 2015, 05:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I just ran into the exact issue last week. As everyone says, PB Blaster or similar, and vice grips. And cursing. Don't forget the cursing.
I tried an impact screwdriver, but the angle is such that it's impossible to get a good smack on it unless the car is on a lift. Even then, it's not so easy. I would not use heat there, too close to the paint for me. Squeeze the vice grips on as tight as you can go, and I'll bet anything it will come out. Be sure and lube the bolt when you replace it. |
| ThePaintedMan |
Feb 13 2015, 05:16 PM
Aha, good point Mike. I forgot that you'd have to get that side of the car up pretty durn high to be able to get the impact in there.
Vice grips it is! |
| rhodyguy |
Feb 13 2015, 05:48 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Soak in between the inner edge of the rocker. Tap, tap, tap on the screw head. Repeat. Heat, spray tap, heat....not something to lean with a set of vice grips. Have a light hand and be patient. Aero-kroil, PBblaster.
| Bulldog9 |
Feb 13 2015, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Thanks for all the advice! What's the best way to apply heat? Blow torch? Heat gun? I really don't want to strip them. I use a heavy duty soldering iron for screws in bodywork works great unless it is totally fused by rust. I don't see a big difference in wd40 or on pbblaster or liquid wrench |
| Tom_T |
Feb 13 2015, 06:09 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Thanks for all the advice! What's the best way to apply heat? Blow torch? Heat gun? I really don't want to strip them. I've always found that Liquid Wrench old formula works best & far better than the PB Blaster ..... another one sold at plumbing stores is "Loose N" as 2nd best. With all, do several sprayings over a few days with soaking over night, & tap on them in between to knock crud loose & let the penetrating oil get in better. Make sure to use the large size screwdriver which fits into the cheeseheads' slots with no play & vice grips on the screwdriver handle as above + if needed, maybe a breaker bar or pipe on the vice grip's handle for more leverage, but that will take 2 - 1 to hold the screwdriver firmly in the slot & straight, the other to turn the breaker bar/pipe. I got mine off that way in 2011 - which hadn't been off since 1980 - 31 years! Good Luck but go slow & carefully! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| pete000 |
I use Worth anti seize on everything !
Next time the screws will come out. Attached image(s)
| warrenoliver |
Feb 13 2015, 06:23 PM
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
couple of years ago, I had the same problem. I got them out by first jacking the car up and putting it on jackstands to give me some clearance. I then got a big ass screw driver with a thick square shank. I put the handle of the screwdriver on my floor jack and jacked it up slowly while positioning the screwdriver blade in the slot of the screw. Once I had it firmly pressed in the slot with the jack, I put a crescent wrench on the screwdriver shank and I was able to back the screws out one at a time. Slow going but very effective. the pressure applied by the jack prevented the screwdriver from slipping out of the slot.
YMMV (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:41 PM |
