2.0 Crankshaft Measurments, Lapping Diameter?? |
pilothyer |
Mar 16 2015, 12:10 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I am looking at the Porsche 914 Factory Manual Volume 1 (914-4 Engine & Clutch) On page 6.3-2/2 There is a chart on reconditioning of crankshaft which gives the crank pin diameters for the mains and the conrods. The first on the list is a new or normal main bearing pin which has a rated diameter of 60 mm, then it shows a measurement called lapping diameter one being 59.990 mm the other 59.971 mm.
I would like to know what the lapping diameter is, what is meant by "lapping dia." ? |
sixnotfour |
Mar 16 2015, 09:35 AM
914 Wizard Group: Members Posts: 10,435 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
lapping = polish
r_towle |
Mar 16 2015, 12:10 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
pilothyer |
Mar 16 2015, 12:46 PM
Thanks for the responses, Can I assume then that as long as the polished dimension is between 59.971 mm and 59.990 mm I would be good to go with standard main bearings?
rgalla9146 |
Mar 16 2015, 08:10 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yes
pilothyer |
Mar 17 2015, 08:42 AM
Thanks (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 06:53 PM |
