Aux air regulator, Red wire what is it |
DavidSweden |
Mar 21 2015, 07:02 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am installing the wiring harness etc on my 76 2.0 engine. I have a thickish black/red wire on the generator harnes that goes to the proximity of the oil pressure switch. The other end of this wire goes to pin 12 on the generator harness connector plug which connects to the relay board . According to the wiring diagram I have pin 12 goes to the fuel pump? I don't think this is correct for my car, does this wire connect to The thin red wire from the auxiliary air regulator?
Help appreciated |
JeffBowlsby |
Mar 21 2015, 07:33 AM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What you are calling the 'generator' harness, we call the ignition harness.
All USA ignition harnesses for D-Jet 914s use a white wire on pin 12 to power the AAR. I have seen an otherwise identical factory original harness that had a thick black/red stripe wire on pin 12 for the AAR, it is possible this is a euro harness, I have no other explanation. Have you found the diagrams for your car on my website for reference? http://bowlsby.net/914/WiringHarnesses/ |
DavidSweden |
Mar 21 2015, 02:08 PM
What you are calling the 'generator' harness, we call the ignition harness. All USA ignition harnesses for D-Jet 914s use a white wire on pin 12 to power the AAR. I have seen an otherwise identical factory original harness that had a thick black/red stripe wire on pin 12 for the AAR, it is possible this is a euro harness, I have no other explanation. Have you found the diagrams for your car on my website for reference? http://bowlsby.net/914/WiringHarnesses/ Jeff, Thanks for setting me right, yes I mean the ignition harness, I will connect the red/black to the AAR. Thanks again |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:37 AM |
