> Pertronix Ignitor III, any experience P-related or not?
sportlicherFahrer
post Apr 6 2015, 06:15 PM
Nothing to see here.
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
7 Pages V  1 2 3 > »
Replies(1 - 19)
76-914
post Apr 6 2015, 09:38 PM
colingreene
post Apr 7 2015, 11:00 AM
I personally have had problems with the parts they sell.
but it works for others
Java2570
post Apr 7 2015, 12:20 PM
I've heard of others using Ignitor II but I'm thinking the Ignitor III won't be compatible with the 914 components. I would try calling Pertronix about it first....I don't see anything on their site saying it
would work with our setups. I'm wrong a lot though so....YMMV!
SKL1
post Apr 7 2015, 12:45 PM
Why would this be better than Permatune? I've had a Permatune on my '71 for years with no issues...
SLITS
post Apr 7 2015, 12:48 PM
"This Utah shit is HARSH!"
QUOTE(Java2570 @ Apr 7 2015, 11:20 AM) *
I didn't see anything about Bosch distributors on their site as well. Limited production for Detroit Iron is all I saw.
sportlicherFahrer
post Apr 7 2015, 01:01 PM
Part number 71847v. They run about $130 on Summit and Ebay. Curious to know if they are as easy to set up as the ignitor 1 and 2. I like that the whole set up fits under the cap still, but is multiple spark and also has a rev limiter. If the 3 works well in other applications, it ought to do so on a type 4 engine as well. Good price for that kind of ignition control.
I figure if they are listing the part number it will at least bolt in with a possible mod for the vacuum advance that is needed for the 1 &2.
Java2570
post Apr 7 2015, 01:27 PM
I don't see the specific instructions for the 71847v but the other Ignitor III install procedures look very similar to how the Ignitor I & II install. Buy one and try it out and post a review of how it works....
you are elected class guinea pig!! (IMG:style_emoticons/default/piratenanner.gif)
euro911
post May 25 2015, 04:55 PM
I've been running a -II on my 2056 for over 3 years now - but I still carry a spare dizzy w/points just in case (IMG:style_emoticons/default/shades.gif)
boxsterfan
post May 25 2015, 05:23 PM
914's are kewl
Opinions on the Pertronix are like reviews on Amazon. Some love/like....some hate. I have Pertronix II. Never bothered me. Either carry spare points, spare Pertonix or have a towing plan with your car insurance. All easily solvable problems.
Dave_Darling
post May 25 2015, 08:35 PM
914 Idiot
QUOTE(SKL1 @ Apr 7 2015, 11:45 AM) *
The Permatune is a Capacitive Discharge Ignition. It makes the spark hotter, and offloads a lot of the current flow from the points. It still uses points, but they pass a low "switching" current rather than the full ignition current.
The Pertronix completely replaces the points, but does not change the way the ignition circuit works. It doesn't make the spark noticeably hotter, but it won't wear like points do.
They're different bits doing different jobs.
--DD
iankarr
post May 25 2015, 09:17 PM
I have a P-III on my 65 mustang. Works great. The big diff between the II and the III is that with the III you don't need to install a ring over your dizzy shaft. It senses when the lobe spins around (by the change in magnetic field).
Anyway, my PIII works great. Not sure if it's compatible with the 914. If it is, keep in mind that it either works or it doesn't...it's not like points which give you some notice when they're worn or on their way out. When the pertronix dies, it'll happen in an instant and you'll be stranded. That's why many P users keep a spare set of points or a spare PIII in the trunk (myself included)!
Jetsetsurfshop
post Aug 10 2017, 04:48 PM
You guys that are using the Pertronix III, what coil and plug wires are you using?
Also, did you increase you spark plug gap?
Thanks in advance. (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations
post Aug 10 2017, 06:20 PM
I. I. R. C.
Jet, check the classifieds. I have a Pertronix SVDA distributor and coil for sale
bandjoey
post Aug 10 2017, 07:13 PM
bandjoey
II installed on otherwise stock (blue coil) motor. 3 years not not a drop of trouble... and now it'll probably quite tomorrow. (IMG:style_emoticons/default/biggrin.gif)
solex
post Aug 11 2019, 01:39 PM
I just installed the III and cannot seem to get the engine to idle any one have any experience with getting the III run in a stock 2.0 D-JET?
Also I'm running a stock coil, I checked the resistance and it is 2.3 ohms with no wire attached and am running Magencore Electrosport 70 SS25 200T spark plug wires.
Any thoughts or direction would be appreciated.
Regards,
Dan
porschetub
post Aug 11 2019, 03:14 PM
QUOTE(solex @ Aug 12 2019, 07:39 AM) *
Regards,
Dan
I've run a stock and Bosch blue coil with Ignitor 1 but pertronix matching coil with Ignitor 11, I don't know the impedance required for the Ignitor 111 but would be surprised if the stock is compatible.
Do you have the correct air gap between pickup and dizzy shaft ?,1mm from memory.
You can't run solid core leads with the newer ones as per instructions.
bbrock
post Aug 11 2019, 03:45 PM
According to the Pertronix III instructions, it is compatible with any coil of 0.32 Ohms or greater so should work with stock coil. http://support.pertronix.com/file.php?key=...1a66cdecbd8493f
I recently bought and installed a Pertronix III and their matching Flamethrower III coil but am months away from firing up the engine so can't comment on how well it works.
As Ian mentioned, there is no magnetic ring under the rotor with the Pertronix III ande is no adjustment for air gap.
SteveL
post Aug 11 2019, 03:53 PM
I have had a Pertronix in place of the points for 15-20 years now, must be a series 1 if that old. Never an issue.
solex
post Aug 11 2019, 05:18 PM
I checked everything even called Pertronix prior to purchasing to make sure the plug wires I had were good. I will have to call them again.
I may need to downgrade to a II or I or back to good old points and condenser.
Thanks for the responses
7 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 6th June 2026 - 11:27 AM
