WTB Thermostat flaps Assy. |
80cap |
Apr 15 2015, 03:11 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I am missing the thermostat assembly for my 2.0. I have the Thermostat.
Thanks Brian |
TheCabinetmaker |
Apr 15 2015, 03:34 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Do you need the bracket that holds the thermo, or the flaps?
80cap |
Apr 15 2015, 04:04 PM
I need everything except the thermostat.
Thanks Brian |
TheCabinetmaker |
Apr 15 2015, 05:32 PM
Ok, I have everything but a good thermostat. Rod, flaps, plastic bearings, springs, flat metal tabs, and thermo mount bracket. Your thermo should have a wire. If not I have that too. The thermo should be closed when cold. Like an accordian that's in the closed position.
$40.00 plus shipping. |
carl07760 |
Apr 16 2015, 05:56 AM
Newbie Group: Members Posts: 3 Joined: 11-August 14 From: new jersey Member No.: 17,763 Region Association: North East States |
if you have a 2nd i will take it
Ok, I have everything but a good thermostat. Rod, flaps, plastic bearings, springs, flat metal tabs, and thermo mount bracket. Your thermo should have a wire. If not I have that too. The thermo should be closed when cold. Like an accordian that's in the closed position. $40.00 plus shipping. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:34 PM |
