carbs/40 IDF's, not finding some things I expected |
Triaddave |
May 18 2015, 05:55 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
O.K., My 44 IDF's are too much for the 2056 engine I built. So now I am re-building some 40 IDF to replace the 44's. I expected to find the starter valve, the guide and the spring(also, wasn't there a ball bearing in there too?). I had no place to install a choke cable or pre-start assembly. Is that stuff always in there or can I just continue with the re-build?
Triaddave |
May 18 2015, 06:07 PM
Oh yea, If you have a WEBER book, It is pictured on page 165-5.17
'73-914kid |
May 18 2015, 06:27 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Many new Webers made in Spain are not machined for the choke setup. Don't worry about it, and carry on.
vw505 |
May 18 2015, 06:38 PM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
If your 44s workedmwell have you thought of putting in smaller vents, i dropped mine from 36mm to 32mm on my 2056.
Mblizzard |
May 18 2015, 07:25 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
If your 44s workedmwell have you thought of putting in smaller vents, i dropped mine from 36mm to 32mm on my 2056. (IMG:style_emoticons/default/agree.gif) 32s on my 44s were very nice. 28s made the low end very strong. |
sgetsiv |
May 18 2015, 07:44 PM
Former 914 Owner :( Group: Members Posts: 159 Joined: 20-June 08 From: Portland, OR Member No.: 9,192 Region Association: Pacific Northwest |
Have you measured AFR? Idle jets? Mains? AC's?
Carb tuning has to be done with some data and likely a few different jetting options. EMPI's or Webers? |
rhodyguy |
May 19 2015, 11:12 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i returned your call this am dave.
Lo-Fi Version | Time is now: 7th June 2024 - 11:27 PM |
