plug wire routing, over or under intakes? |
oakdalecurtis |
Jun 9 2015, 02:24 PM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
76 2.0 engine, does it matter if the plug wires are routed over or under the intake runners?
screenguy914 |
Jun 9 2015, 03:57 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
oakdalecurtis |
Jun 9 2015, 04:05 PM
76 2.0 engine, does it matter if the plug wires are routed over or under the intake runners? Not unless you subject your car to inspection by the folks with white gloves and clipboards. Ok, I give up, where do the white glovers want to see em? |
screenguy914 |
Jun 9 2015, 04:16 PM
76 2.0 engine, does it matter if the plug wires are routed over or under the intake runners? Not unless you subject your car to inspection by the folks with white gloves and clipboards. Ok, I give up, where do the white glovers want to see em? Didn't realize what mattered to you, appearance or function. Maybe find an image of a factory 914 sales brochure or equivalent. |
dlee6204 |
Jun 9 2015, 04:28 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Under. There are holes in the top of the engine tin specifically for spark plug wire clips.
Tom |
Jun 9 2015, 06:12 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Make sure #3 is routed under the intake runner. #3 plug wire has been known to interfere with the MPS signals.
Tom |
76-914 |
Jun 9 2015, 06:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
rick 918-S |
Jun 9 2015, 06:30 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Lo-Fi Version | Time is now: 29th May 2024 - 03:38 AM |
