Experienced bodywork guys - how would you fix this? |
patssle |
Jun 11 2015, 04:57 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
914's aren't overly popular here in Houston but I've found a guy that does good body work on all classic cars and has some experience with 911 and 914. I wanted to check with the experts that have dealt with bodywork on the 914 in the front cowl/fender area - how would you fix the rust bubbles on this car if it was yours? Does the fender need to be removed for any of the work or only if the rust has penetrated deep into the cowl?
Thanks! (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-10741-1434063473.1.jpg) |
mepstein |
Jun 11 2015, 05:05 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There will be a lot more once you remove the paint.
KELTY360 |
Jun 11 2015, 05:07 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
914Sixer |
Jun 11 2015, 05:24 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Once the rubber comes out and the windshield is removed serious rust will appear.
Mike Bellis |
Jun 11 2015, 05:29 PM
It's rusting from the inside out. The fender should be cut off for a proper repair... Pandora's box...
scotty b |
Jun 11 2015, 05:51 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:style_emoticons/default/agree.gif) what they said. It needs to come off. There's going to be a mess inside that will need to be repaired
aufgates |
Jun 11 2015, 06:42 PM
Newbie Group: Members Posts: 14 Joined: 4-June 15 From: CT Member No.: 18,797 Region Association: None |
bondO
bulitt |
Jun 11 2015, 07:39 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Read through this thread and you will see all the fixes...
http://www.914world.com/bbs2/index.php?sho...=183248&hl= |
Cairo94507 |
Jun 11 2015, 11:28 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
If you decide to tackle that, please do it the right way. Do not let someone just fill it with bondo.
Personally, we have some serious experts on this board that know these cars inside and out. Scotty, who has already rung in, is one of them - and the man doing my car. I always approach something that if it is going to get fixed, I want it done 100% correctly, like the factory would do it, so I do not have to revisit it 3 years down the road. Just my 2 cents. |
Claus Graf |
Jun 12 2015, 05:59 AM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
Once you start digging, it will get ugly.......fast.
That area also is filled from the factory with some type of foam. Claus Graf |
cary |
Jun 12 2015, 08:53 AM
patssle |
Jun 12 2015, 04:54 PM
I don't like y'all opinions! But thanks for the info.
I put together a photo album of all the previous work done on the cowl/fender area by other people and am prepared for the worse. But I think the guy I found is a quality bodywork guy and will do it right. I'll certainly update with photos of what is underneath. |
patssle |
Jul 11 2015, 11:38 AM
Well it wasn't as bad as everybody thought. The seam sealer under the panel had some rust in it but once cleaned away underneath the metal had a little surface rust that was easily cleaned. Been a nagging problem ever since I bought the car but finally got a couple rust bubbles fixed, holes filled, and dents repaired. Paint or wrap is up next!
Cj Honeycutt |
Jul 11 2015, 12:18 PM
Member Group: Members Posts: 50 Joined: 7-August 10 From: Fallbrook, CA Member No.: 12,020 Region Association: Southern California |
Looks nice ! What was the final cost to primer ?
patssle |
Jul 11 2015, 01:41 PM
It was about $1000 for two days of work. I also removed the rear reflector and it had many holes underneath which he filled. Filled the antenna and passenger mirror holes as well.
Lo-Fi Version | Time is now: 8th June 2024 - 04:00 AM |
