Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Thinking of a fire suppression system, but halon is so expensive, I think foam systems freeze and I'd hate to dump a chemical bottle on it.
Automatic, no residue, looks like a good system, you would just zip tie it to the lid. Only downside I see is the ugly hose in the compartment. My one question would a GT lid be closed in enough to make this work proper? http://jogrusa.com/products/blazecut-fire-suppression-system https://www.youtube.com/watch?v=Kswau1mGBE8 |
2ma2 |
Newbie ![]() Group: Members Posts: 9 Joined: 4-June 14 From: california Member No.: 17,436 Region Association: None ![]() |
That looks awesome on the video. I would like to hear a few positive reviews from real world users and then I'd put one in all my older cars
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
This pops up here from time to time. Seems like cheap protection IF it is installed at the ideal location to put the fire out.
I run a Firecharger AFFF fire foam system. My system can be recharged at home and is less caustic than other chemical systems. https://www.pegasusautoracing.com/group.asp...upID=FIREPARTFC ![]() |
Mark Henry |
This pops up here from time to time. Seems like cheap protection IF it is installed at the ideal location to put the fire out. I run a Firecharger AFFF fire foam system. My system can be recharged at home and is less caustic than other chemical systems. https://www.pegasusautoracing.com/group.asp...upID=FIREPARTFC To me the freezing issue makes it a total no go. |
Mike Bellis |
This pops up here from time to time. Seems like cheap protection IF it is installed at the ideal location to put the fire out. I run a Firecharger AFFF fire foam system. My system can be recharged at home and is less caustic than other chemical systems. https://www.pegasusautoracing.com/group.asp...upID=FIREPARTFC To me the freezing issue makes it a total no go. The only thing that freezes around here is ice cubes in my fridge. (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
This pops up here from time to time. Seems like cheap protection IF it is installed at the ideal location to put the fire out. I run a Firecharger AFFF fire foam system. My system can be recharged at home and is less caustic than other chemical systems. https://www.pegasusautoracing.com/group.asp...upID=FIREPARTFC To me the freezing issue makes it a total no go. The only thing that freezes around here is ice cubes in my fridge. (IMG:style_emoticons/default/biggrin.gif) yeh, yeh, yeh....but I can fill my pool with tap water, in fact I'am doing that right now. (IMG:style_emoticons/default/shades.gif) |
Mike Bellis |
This pops up here from time to time. Seems like cheap protection IF it is installed at the ideal location to put the fire out. I run a Firecharger AFFF fire foam system. My system can be recharged at home and is less caustic than other chemical systems. https://www.pegasusautoracing.com/group.asp...upID=FIREPARTFC To me the freezing issue makes it a total no go. The only thing that freezes around here is ice cubes in my fridge. (IMG:style_emoticons/default/biggrin.gif) yeh, yeh, yeh....but I can fill my pool with tap water, in fact I'am doing that right now. (IMG:style_emoticons/default/shades.gif) I can fill my pool with tap water. It will just cost me $20,000 in fines. It's about a foot low right now... (IMG:style_emoticons/default/sad.gif) |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
You could probably paint the hose and components flat black, it would pull heat faster and be less noticeable.
This is a great looking system, I doubt it would deploy unless the car was really on fire and parked as shown. Im considering this now... |
Lo-Fi Version | Time is now: 31st July 2025 - 05:43 PM |
