| PanelBilly |
Jun 14 2015, 10:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I had unbted the trNsmission and allowed the drivetrain to angle down a bit so I could slip the axle out on one side and when I bolted it back up I found that the engine shifted back a tiny bit. The only problem now is that my rain hats on the PMOs won't fit. It was a close fit before, but now it's too tight. There isnt much slop in the engine mount, but I need to loosen The bolts and make it slide foward a quarter inch or so
| Bob L. |
Jun 14 2015, 11:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I'd loosen the tranny mounts as well.
| rgalla9146 |
Jun 14 2015, 11:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,944 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Also check for broken mounts if it's a late 4 cyl.
| Luke M |
Jun 14 2015, 01:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
IIRC you have a 6 cyl conv with a RJ engine mount?
If so the engine mounts are bolted into a slotted grove (front to rear). This may have shifted towards the rear causing your problem. Worth a look at it to be sure. |
Lo-Fi Version | Time is now: 18th March 2026 - 10:29 AM |
