> DAPO Clutch Tube Repair, More Headaches
914Sixer
post Jun 19 2015, 05:42 PM
My plan for today was simple for today. I was going to install the short shifter. I knew that the clutch tube had been repaired because I could see it in the rear. After I got the console out is when the fun began. I pulled up the carpet and found 2 tunnel cuts. I peeked under the cuts and things looked good. I pulled the shifter and then found this mess. (IMG:style_emoticons/default/headbang.gif)
The weld had broken and looked rubbed. I flipped the shifter over and found that they had ground the shifter lever. This explained why the shifter was stiff in reverse and first.
Now I will have to get the cutting wheel and burr grinder and cut center mess out. (IMG:style_emoticons/default/sawzall-smiley.gif)
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Replies(1 - 2)
Cairo94507
post Jun 20 2015, 07:01 AM
Michael
Nice! Glad you found it so it can be repaired correctly. Another issue off the list. (IMG:style_emoticons/default/biggrin.gif)
r_towle
post Jun 20 2015, 09:19 PM
Custom Member
Take the cable out while welding the tube....sorry to say.
It's very thin metal, so brazing it may be better if you have a torch.
- Lo-Fi Version Time is now: 1st August 2025 - 04:32 PM
