Oil drain fitting, Is something available? |
GeorgeRud |
Jul 5 2015, 03:35 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
My conversion car uses the metric sized hoses from the oil tank to the cooler, with fittings to allow for changing the oil. Does anyone make a fitting that would allow one to simply unscrew a cap or plug instead of separating the 32 and 36mm fittings? After spilling oil during today's oil change, I think there must be another way. If the hoses were AN sized, a simple T fitting with a cap would do the truck, but i don't know if anyone makes a metrick T fitting.
screenguy914 |
Jul 5 2015, 04:13 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
No drain plug on the tank? Okay.
One option is to source an AN-NPT-AN tee, then install a Fumoto ball valve into the NPT center port. You may have to find a tee with female and male AN ends to splice into an existing hose connection. They're out there. Sherwood |
GeorgeRud |
Jul 5 2015, 04:26 PM
The connection point on a 914-6 is not on the oil tank, but rather by the trailing arms in between the two hoses. That's where my car has a fitting that both hoses attach to, and that's the one that I'd like to find an easy drain option like the pictured valves.
Dave_Darling |
Jul 6 2015, 09:11 AM
i don't know if anyone makes a metrick T fitting. Since everyone else in the world but us uses metric fasteners, I'd be astonished if nobody made one. Check with your local tractor supply. Caterpillar is evidently one of the largest users of metric fasteners on the planet. Failing that, check McMaster-Carr and then start Googling. --DD |
Lo-Fi Version | Time is now: 7th June 2024 - 06:47 PM |
