side shift console - Is this OK to use? |
mikedsilva |
Jul 6 2015, 04:36 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
I bought some parts from Brad Mayeur to convert my tailshift to sideshift...
I have the engine and trans out and when I went to clean up the parts, I noticed that the area of the side shift console is a bit "corroded" just outside of the o ring area. So, for those that are familiar with these components, can i simply change the o-ring and install, or should I take it to a machine shop for careful milling? My little soda blaster was not able to shift any of the raised areas.... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179000.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179001.2.jpg) |
Tbrown4x4 |
Jul 6 2015, 05:46 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I would attempt a gasket scraper and wire brush. Either way it's not the sealing surface, so as long as the o-ring groove is clean, it should be OK.
914ltd |
Jul 6 2015, 06:39 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
The corrosion is not on a sealing surface, dress any unevenness with a file.
We now use Curil T along with the O ring for a positive seal. 40+ year old magnesium can warp in areas like this especially if it has been overtightened in the past. Brad |
Lo-Fi Version | Time is now: 1st June 2024 - 10:34 AM |
