O Ring for side shift console |
john77 |
Jul 17 2015, 11:06 AM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I just got a tangerine side shift linkage and figured, as my side shift console is leaking pretty bad, that I'd pull it to do the needed mods for the linkage and put in new seals at the same time [I'll be doing the speedo drive while the oil's out too.]
I have the seal for the selector rod, but don't have the o ring that goes between the console and the tranny. Is it possible to buy this separately? All I can find is the whole pack of 901 seals for $89. If not, I'm wondering if I can't just buy the same sized O-ring off ebay or amazon. I mean, an o-ring is an o-ring is an o-ring, right? Or not right? John |
Harpo |
Jul 17 2015, 11:16 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I agree. Measure the diameter of the "O" ring and ID & OD and search on McMaster Carr and see what your options are
stugray |
Jul 17 2015, 11:38 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am confident that if you asked Dr Evil, he would have a loose one he would part with.
john77 |
Jul 17 2015, 12:24 PM
I am confident that if you asked Dr Evil, he would have a loose one he would part with. Thanks Stu, I'll give him a try. I mean, techinically, his DVD is partly to blame for me even doing this, so... (IMG:style_emoticons/default/biggrin.gif) |
mikedsilva |
Jul 17 2015, 01:59 PM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
Have you tried genuine Porsche parts?
That's where i got mine... Mike. |
ThePaintedMan |
Jul 17 2015, 02:05 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Pelican has them too. Though you might think of other stuff you want to order at the same time to save on shipping.
john77 |
Jul 17 2015, 02:36 PM
ThePaintedMan |
Jul 17 2015, 03:24 PM
Yep, it's here:
http://www.pelicanparts.com/catalog/SuperC..._TRANSM_pg4.htm under "Manual Transmission Selector Rod, Shims and Seals" - part number 999-701-359-40. In case you ever need to look up specific part numbers in the future, check out the Porsche PET below: http://www.porsche.com/all/media/pdf/origi...USA_KATALOG.pdf Usually you can put the part number into Google and get a pretty good handle on the folks who stock it. |
john77 |
Jul 17 2015, 04:41 PM
Yep, it's here: http://www.pelicanparts.com/catalog/SuperC..._TRANSM_pg4.htm under "Manual Transmission Selector Rod, Shims and Seals" - part number 999-701-359-40. In case you ever need to look up specific part numbers in the future, check out the Porsche PET below: http://www.porsche.com/all/media/pdf/origi...USA_KATALOG.pdf Usually you can put the part number into Google and get a pretty good handle on the folks who stock it. Awesome, thanks George, this is exactly what I need. |
Lo-Fi Version | Time is now: 12th June 2024 - 07:39 AM |
