OIL TOO HOT?, HOW TO RUN COOLER. |
chazt74914 |
Jul 20 2015, 11:23 AM
CHAZT54 Group: Members Posts: 18 Joined: 8-July 14 From: New London, WI Member No.: 17,600 Region Association: None |
Took my '74 2.0 to a car show yesterday about 40 miles away.
I took the back roads on the way there and by the time I got there the oil temp had leveled off at 230' - I am told this is warm but not cause for concern. On the way home I decided to take the interstate and after about 20 mi. at 75 MPH THE OIL TEMP HAD CLIMBED TO 260' (2200 RPM in 5th) So I got off this road and after a break to let it cool, I proceeded on the back roads keeping the R's above 3,000 at slower speeds but it didn't seem to help much. Made it home with no problem and a pull of the dipstick shows good, unburnt, clean oil. How concerned should I be and what should I look for? NOTE; ambient temp was 85' (IMG:style_emoticons/default/confused24.gif) Thanks in advance for any help. CHAZT |
damesandhotrods |
Jul 20 2015, 11:37 AM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
The air dam is disrupting under car air flow which would naturally lead to higher temps at sustained highway speeds…
DRPHIL914 |
Jul 20 2015, 12:13 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
not necessarily , very common issue with the 2.0 cars it seems; my 75 has had the same issue and i had a similar thread started a couple weeks ago on this same subject. mine was hitting the 240+ range with temps at 95 degrees outside, but pushing that 225- 240 range with air temps in the 80's which seems a bit more than it should be. , some factors include RPM's, hills vs flat land, type of and viscosity of oil, air flow under car and around heads, and thry oil cooler. im going to put in an external larger cooler replacing the stock one - looking at the kits that Tangerine racing has right now. I got up to 250-260 climbing the tail of the dragon last year at octeenerfest and it was only 75 degrees out!!
- what oil are you running? are you sure there is no debris under the tin or over the oil cooler? Phil |
brant |
Jul 20 2015, 12:15 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree the air damn will cause part of the extra heat
is it carb'd maybe richen the mixture double check the timing and possibly retard it and if you have never taken the tin work off to clean out the stock cooler that might be in order also |
DRPHIL914 |
Jul 20 2015, 12:25 PM
I agree the air damn will cause part of the extra heat is it carb'd maybe richen the mixture double check the timing and possibly retard it and if you have never taken the tin work off to clean out the stock cooler that might be in order also (IMG:style_emoticons/default/agree.gif) good point , my temps did improve when timing was reset and i was running a bit more rich. i was on the lean side and that does make a difference, even with d-jet, . - some have had seen a temp difference using a thinner lower viscosity oil, going from a 20/50 to a 10/40, etc. |
Big Len |
Jul 20 2015, 12:36 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
How are you doing 75 mph @2200 rpm in 5th?
EdwardBlume |
Jul 20 2015, 12:53 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
It's the air dam. Take it off and retry. I used to run that type for AX but left it off for longer distance.
Ferg |
Jul 20 2015, 01:00 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
All the easy stuff that should help. In the end, if you want to see below 220 on hot days after running hard and long a oil cooler is almost always needed.
Air Dam removal. Remove rain tray make sure engine flaps operating make sure undercarriage chassis flaps present Check fan for obstruction Tune and check mixture with sniffer or the like. |
Elliot Cannon |
Jul 20 2015, 02:47 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Right after I installed the low airdam on my car, oil temps started running high. I installed an after market, aux. oil cooler fed through a NACA scoop in the rocker panel, via a 3 inch duct to a cowl surrounding the cooler. Resulting in much cooler oil. You can do something like that or simply go back to a stock front valance. (But where's the fun in that)? (IMG:style_emoticons/default/biggrin.gif) By the way, your car looks great. (IMG:style_emoticons/default/first.gif)
Attached image(s) |
pda914 |
Jul 20 2015, 02:51 PM
Newbie Group: Members Posts: 40 Joined: 22-July 10 From: Verona WI Member No.: 11,966 Region Association: None |
I also had the issue with oil temps getting to 230. At that time I did not have an air dam. I added the air dam and went into the Megasquirt configuration and flattened out the timing advance a bit. Now the oil temp stays at 195 on the highway (70 mph during an hour drive on the highway) and in town it may push up to 205. Air temps were in the high 70's.
era vulgaris |
Jul 20 2015, 03:58 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
How are you doing 75 mph @2200 rpm in 5th? (IMG:style_emoticons/default/agree.gif) That would be closer to 60mph wouldn't it? Not that I'd know. I don't run 5th gear at any less than 3500 rpm, preferably closer to 4K. Running at 2200rpm in 5th is a great way to overheat your heads and cause burned valves and/or cracked heads. That's a lot of air-resistance your car has to push through at that speed, and it causes a lot of unnecessary load on the engine with your rpm's that low. This isn't a water-cooled car, don't drive it like one. |
thelogo |
Jul 20 2015, 04:03 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
How are you doing 75 mph @2200 rpm in 5th? . This isn't a water-cooled car, don't drive it like one. Fuckin classic , I love it (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol-2.gif) |
914itis |
Jul 20 2015, 04:59 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I agree the air damn will cause part of the extra heat is it carb'd maybe richen the mixture double check the timing and possibly retard it and if you have never taken the tin work off to clean out the stock cooler that might be in order also (IMG:style_emoticons/default/agree.gif) good point , my temps did improve when timing was reset and i was running a bit more rich. i was on the lean side and that does make a difference, even with d-jet, . - some have had seen a temp difference using a thinner lower viscosity oil, going from a 20/50 to a 10/40, etc. (IMG:style_emoticons/default/agree.gif) My car ran 20 degrees higher when switched from 10/40 to 20/50 I switched back and it's back to normal. |
DRPHIL914 |
Jul 20 2015, 06:56 PM
I agree the air damn will cause part of the extra heat is it carb'd maybe richen the mixture double check the timing and possibly retard it and if you have never taken the tin work off to clean out the stock cooler that might be in order also (IMG:style_emoticons/default/agree.gif) good point , my temps did improve when timing was reset and i was running a bit more rich. i was on the lean side and that does make a difference, even with d-jet, . - some have had seen a temp difference using a thinner lower viscosity oil, going from a 20/50 to a 10/40, etc. (IMG:style_emoticons/default/agree.gif) My car ran 20 degrees higher when switched from 10/40 to 20/50 I switched back and it's back to normal. And what brand are you running now? |
dangrouche |
Jul 20 2015, 07:02 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
refrerence what Jake Raby has said; third comment down
http://www.914world.com/bbs2/index.php?sho...temp,and,normal |
914itis |
Jul 20 2015, 07:33 PM
I agree the air damn will cause part of the extra heat is it carb'd maybe richen the mixture double check the timing and possibly retard it and if you have never taken the tin work off to clean out the stock cooler that might be in order also (IMG:style_emoticons/default/agree.gif) good point , my temps did improve when timing was reset and i was running a bit more rich. i was on the lean side and that does make a difference, even with d-jet, . - some have had seen a temp difference using a thinner lower viscosity oil, going from a 20/50 to a 10/40, etc. (IMG:style_emoticons/default/agree.gif) My car ran 20 degrees higher when switched from 10/40 to 20/50 I switched back and it's back to normal. And what brand are you running now? Valvoline VR1 With added zinc. |
DRPHIL914 |
Jul 20 2015, 08:29 PM
I'm going to go back and recheck the timing, and do an oil change . I've been running 20/50 vr1, will try the 10/40.
See what happens. |
chazt74914 |
Jul 21 2015, 11:50 AM
Thanks for all the input guys.
I am running Quaker State straight SAE30 (non-syn). I will look under the tins and check the cooler for obstructions and remove the air dam for now to see if it helps. (do the simple stuff first) The flaps are wired open because I do not take this out in cold weather. It still has the OEM injection system which has been trouble free since I disabled the cold start valve. 75MPH @ 2,200 IN 5TH - that's what I am reading. Anyone else think that is whacked? CHAZT |
stugray |
Jul 21 2015, 11:56 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Thanks for all the input guys. I am running Quaker State straight SAE30 (non-syn). I will look under the tins and check the cooler for obstructions and remove the air dam for now to see if it helps. (do the simple stuff first) The flaps are wired open because I do not take this out in cold weather. It still has the OEM injection system which has been trouble free since I disabled the cold start valve. 75MPH @ 2,200 IN 5TH - that's what I am reading. Anyone else think that is whacked? CHAZT Do a little research on what is considered an acceptable oil in these cars. I dont believe that Quaker State is on any of the lists of oils to use. |
DRPHIL914 |
Jul 21 2015, 12:11 PM
Thanks for all the input guys. I am running Quaker State straight SAE30 (non-syn). I will look under the tins and check the cooler for obstructions and remove the air dam for now to see if it helps. (do the simple stuff first) The flaps are wired open because I do not take this out in cold weather. It still has the OEM injection system which has been trouble free since I disabled the cold start valve. 75MPH @ 2,200 IN 5TH - that's what I am reading. Anyone else think that is whacked? CHAZT I'm just a little above that and I have a modified 4th and 5th gearing (has and flipped x) to give me closer to a 4.4 and 5.5 equivalent. So I run about 600 to 700 rpm less than a standard box on the freeway. Either you also have this set up or your tach is off. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:27 AM |
