stripped wiper fix, old school-914 experience pmb inspired |
sean_v8_914 |
Jul 21 2015, 10:28 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
sometimes the wiper comes loose but the owner didnt stop the wiper drive quick enough so the aluminum wiper arm splines get munched by the steel spindle splines.
a wavy washer fits under the AL nut. the OD of the wave washer is small enough to fit in the recess of the wiper arm. dont forget to clean the shaved AL from teh steel spindle splines |
Kraftwerk |
Jul 21 2015, 12:54 PM
Member Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
This is an easy fix. Get a very small triangular-shaped metal file and deepen all the splines on the wipeR arm. it is soFt aluminum and this works pretty well to get the wiper back on the wiper-pivot. use the original nut and washer.
sean_v8_914 |
Jul 21 2015, 01:05 PM
i can not agree with removing additional material
76-914 |
Jul 21 2015, 07:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had that happen on a Ghia. Wrapped a strip of aluminum foil around the shaft then pulled the arm down on the shaft with the nut. IIRC, I had to do it twice to "build it up". Held till I sold it 13 yr's later.
Lo-Fi Version | Time is now: 10th June 2024 - 10:32 PM |
