Tune-up time |
Tune-up time |
Mykle57 |
Jul 24 2015, 04:34 PM
Newbie Group: Members Posts: 3 Joined: 16-July 15 From: Massachusetts Member No.: 18,961 Region Association: North East States |
Hi folks,
Most of the way through my first tune-up. Now, I'm looking to replace the condenser. I spent about a half hour trying to get the first screw out. Only to find there's another screw on the other side (holding the rubber grommet). pita! Is it recommended to remove the whole distributor just to replace a condenser? (seems excessive. Am I missing something?) |
dlee6204 |
Jul 24 2015, 05:12 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I remove the whole distributor. It's not difficult after you get the hang of it. It's a good time to verify your timing. You'll likely never have to replace the condenser again so that's a plus.
saigon71 |
Jul 25 2015, 05:16 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
After dropping that tiny condenser screw several times, I just pull the dizzy now anytime I mess with it. |
TheCabinetmaker |
Jul 25 2015, 05:32 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
One more. Pull it. While it's out, you can set the point gap at a perfect .016 and your dwell will be pretty darn close.
stugray |
Jul 26 2015, 10:40 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You can pull the dizzy without screwing up the timing.
Just take the one nut off of the holddown plate and it will lift out with some wiggling. Dont loosen the timing adjust nut, and it will go back in with the same timing setting. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:28 AM |
