plastic fuel filters - how horizontal can they be installed |
jimkelly |
Aug 8 2015, 08:48 AM
I need to add another BEFORE my fuel pump and was wondering. my tank has rust and is glogging filters pretty fast but I expect this will subside soon. but till then, I will replace filters frequently. I got a few G15 fram filters on order as well as the fram G3 I already have in my car.
Attached thumbnail(s) |
Mike Bellis |
Aug 8 2015, 10:53 AM
The mounting angle of the filter should not matter.
Elliot Cannon |
Aug 8 2015, 11:00 AM
They must be mounted exactly 23.5 degrees from horizontal with the pressure side being the lower side. Or what Mike said. (IMG:style_emoticons/default/biggrin.gif)
Dave_Darling |
Aug 8 2015, 06:23 PM
That looks like a low-pressure carb-oriented filter. Don't use that for high-pressure fuel injection. It's fine if it's for carbs though.
--DD |
jimkelly |
Aug 8 2015, 06:47 PM
yes, carbed application.
Attached image(s) |
Mikey914 |
Aug 8 2015, 08:24 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That looks like a low-pressure carb-oriented filter. Don't use that for high-pressure fuel injection. It's fine if it's for carbs though. --DD I was thinking the same thing. May want to make sure its rated for fuel injection. At least you're not running them long between changes. |
Lo-Fi Version | Time is now: 6th June 2024 - 09:14 AM |
