1971 914-6 Turn Signal return |
nine11speedster |
Aug 8 2015, 06:22 PM
Carson Group: Members Posts: 55 Joined: 8-February 08 From: Ca, USA Member No.: 8,686 Region Association: None |
Hello gang,
my 71 914-6 turn signal doesn't return. I took the steering wheel off and didn't see the usual plastic ring that sticks out to switch the turn signal off. I wonder if this is the part I m missing or is there something else I need to check? (any idea where to get this plastic ring?) Thanks Carson |
mepstein |
Aug 8 2015, 06:37 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The real 914-6 uses a metal cancel ring on the back of the steering wheel. No mastic ring or hub. It's the same as early 911.
914Sixer |
Aug 9 2015, 07:07 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Look at the switch, the return spring is probably broken or come off.
gms |
Aug 12 2015, 11:35 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Hello gang, my 71 914-6 turn signal doesn't return. I took the steering wheel off and didn't see the usual plastic ring that sticks out to switch the turn signal off. I wonder if this is the part I m missing or is there something else I need to check? (any idea where to get this plastic ring?) Thanks Carson post some pictures and then it will be easier to help you (IMG:style_emoticons/default/smile.gif) |
Mr.242 |
Aug 14 2015, 09:09 PM
May your glass be smaller so it's always FULL! Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 6th June 2024 - 09:25 AM |
