can i put a 1975 tank in a 1972 car? |
jimkelly |
Aug 9 2015, 11:15 AM
my 1972 tank is rusty and my 1975 is pretty clean, see pics.
Attached image(s) |
914werke |
Aug 9 2015, 11:21 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Thats nothing....
but if you choose to replace , Yes |
jimkelly |
Aug 9 2015, 11:24 AM
this pic is of my better tank. my other tank is covered with light surface rust but it is enough to clog my fuel pump in minutes of running. I am sure with enough filters I could clear out the problem but then I would still have the surface rust ever present.
mepstein |
Aug 9 2015, 11:39 AM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
the brackets on top of the tank differ but i'm sure you can work around that.
Good to see the car is getting back on the road. The more running 914's, the better. |
bdstone914 |
Aug 9 2015, 11:56 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Use the 75 tank with wxpansion tank and swap the nippl on the bottom. 75 has two large nipples early has one large and one small.
mepstein |
Aug 9 2015, 02:36 PM
Nipples are important (IMG:style_emoticons/default/biggrin.gif)
jimkelly |
Aug 9 2015, 03:18 PM
one of the nipples on the better tank is buggered, actually it seems to maybe only have some aluminum in the threads BUT I am going to have one port welded shut and have a nipple welded to the other since i am running a carb.
Attached image(s) |
Spoke |
Aug 9 2015, 05:05 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The threads look ok, just the first 3 threads look clogged with garbage. Need to chase them with a bolt or the fitting using a cutting agent or motor oil.
Lo-Fi Version | Time is now: 8th June 2024 - 11:27 PM |
