h4 headlights and Bulbs, Whatcha guys doing? |
TravisNeff |
Mar 1 2005, 04:15 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Another neato find on the 72 is a set of H4 headlamps. They are the US versions (DOT stamp), not the Euro ones.
Anyhow, what are you guys running for bulb wattages and US/Euro lenses? |
sj914 |
Mar 1 2005, 04:19 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
I think I used to run 80/100 on mine.
Whats the difference between euro and DOT, besides it saying DOT approved? |
TravisNeff |
Mar 1 2005, 04:32 PM
US Spec lamps have a different beam pattern than the European ones.
Aaron Cox |
Mar 1 2005, 04:35 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
fluted type lensed
MarkG |
Mar 1 2005, 04:38 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
I use Cibie' Z-beams (U.S. type, i.e. right side of road) in all my 7" headlight cars. 55w standard H4 bulbs.
sj914 |
Mar 1 2005, 04:39 PM
Fluted? you mean the lenses with the lines running vertically on them.
drgchapman |
Mar 1 2005, 04:40 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
80/100's. Great vision at night. Draws down the battery, so need beefed up alternator.
TravisNeff |
Mar 1 2005, 04:44 PM
I have to dig into that already, when I turn on the headlights I start getting the alt light. Replacing the positive and ground cables this weekend ought to help a little.
scruz914 |
Mar 1 2005, 05:02 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
Anyone experience problems with the standard wires when running the higher watt bulbs?
sj914 |
Mar 1 2005, 05:17 PM
I never had any battery or alt. problems when I ran with the 80/100 bulbs.
azbill |
Mar 1 2005, 05:26 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
I'm using DOT H4's - I like them
TravisNeff |
Mar 1 2005, 05:42 PM
What bulbs are you running Bill?
The wiring most probably needs to be upgraded with two relays and a biggun wire directly from the battery. I read today that if your wiring drops a volt or two your 100 watt bulbs are really only 80 watts. |
Aaron Cox |
Mar 1 2005, 06:19 PM
where did you buy them? and how much?
ejm |
Mar 1 2005, 07:00 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The bigger problem is the ignition and headlight switches...they will heat up trying to handle the load of upgraded lights. Relays will greatly extend the life of these parts. Anyone price a headlight switch lately? |
Joe Ricard |
Mar 1 2005, 07:20 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Euro H-4's with 55/65 W bulbs stock wiring. Great lights. 100 W driving lights on heavy wire with relay. Melts the bumpers off Hondas.
Mark Henry |
Mar 1 2005, 07:54 PM
euro H4's std bulbs and pilot lights.
Aaron Cox |
Mar 1 2005, 07:58 PM
where do you get them??
Series9 |
Mar 1 2005, 08:04 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Is mine Euro or US? I thought it was Euro, but I got these right after I got the car in '98 and now I can't remember.
Attached image(s) |
TravisNeff |
Mar 1 2005, 08:53 PM
Look for an embossed, or I should say raised spot on the lens that says DOT, can't miss it. If it doesn't have it, you are gonna need off road knoby tires on that thing (euro spec off road use in US), heh.
redshift |
Mar 1 2005, 08:55 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
It's real small....
look real close, with the brights on. M |
Lo-Fi Version | Time is now: 9th June 2024 - 12:00 PM |
