Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I installed a dual pole VDO sender with the kit it came with and am leaking oil at the
female NPT connector joint. The female nut rotates independently of the tube. I'm not sure how that joint seals. Is there an o-ring in there that may have dried out since this is NOS? Would it be okay to cut the tube and replace with a barbed to 1/8" NPT female fitting? ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Just go get a Grease gun extension hose.
Same threads and will probably cost the same as a brass hose barb. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:50 PM |
