Stock 914-6 wiring question, Where does this go? |
Gcthielen |
Sep 10 2015, 01:50 PM
Newbie Group: Members Posts: 37 Joined: 14-August 13 From: Dayton OH Member No.: 16,251 Region Association: Upper MidWest |
Hoping to start my 71 914-6 that has been dormant since 1984. I purchased it disassembled and am very close. However, I do NOT want to fry the ingition box.
I have one ground connected to the box but there is another terminal that is not currently being used. I can not find a blue/black wire on my diagrams that are in the engine bay. See photo.. any hints? The photo shows the firewall in the background and the battery tray is in the right lower corner. Thanks! George |
mskala |
Sep 10 2015, 02:23 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I'd have to look at the diagrams when I get home, but those look like the wire
that goes to the distributor points and the ground that connects to the chain box. |
rgalla9146 |
Sep 10 2015, 02:51 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I concur !
The points wire is the only female in the area. 2 coil leads (small - and +) and 2 grounds (6mm,8mm) are all eyelets |
larryM |
Sep 10 2015, 02:53 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
most porsches have multiple ground wires
what color is the ring-end wire underneath that insulating sheath - and where are these wires - can't tell from your pic wher/what we are looking put an ohmmeter on the wires & find where the other end is; also put a voltmmeter on 'em & see if you have juice on 'em, ign-on, ign-off |
Gcthielen |
Sep 10 2015, 03:13 PM
mskala |
Sep 10 2015, 04:53 PM
My diagram shows the points connection to be black. (IMG:style_emoticons/default/confused24.gif)
On the engine harness, there is not a lot of room for things to go to unexpected places. Let's turn this around; is there already something connected to the points? |
rgalla9146 |
Sep 10 2015, 05:35 PM
The green black wire is oil temp.
It is female. The wire attaches across the back of the connector kinda like a flag. The temp sender is on the drivers side of the crankcase. pic attached The big boot on your battery tray is for the battery cable at the starter Sorry for the dusty engine. Attached thumbnail(s) |
Gcthielen |
Sep 10 2015, 09:25 PM
The green black wire is oil temp. It is female. The wire attaches across the back of the connector kinda like a flag. The temp sender is on the drivers side of the crankcase. pic attached The big boot on your battery tray is for the battery cable at the starter Sorry for the dusty engine. Thanks! I was wondering about that boot.. Now, if I can figure out if both of my CD Box grounds are supposed to be used and if not, where that blue/black female goes...I wish the car were here, but I will be able to look again tomorrow... George |
Gcthielen |
Sep 11 2015, 01:09 PM
gereed75 |
Sep 11 2015, 01:51 PM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I'd have to look at the diagrams when I get home, but those look like the wire that goes to the distributor points and the ground that connects to the chain box. You were correct! Thx! George Chainbox ground???? (IMG:style_emoticons/default/confused24.gif) Aha........ I have an extra unattached ground and that would explain it. (IMG:style_emoticons/default/idea.gif) So where does the ground attach to the chainbox?? Thanks |
mskala |
Sep 11 2015, 04:36 PM
I'd have to look at the diagrams when I get home, but those look like the wire that goes to the distributor points and the ground that connects to the chain box. You were correct! Thx! George Chainbox ground???? (IMG:style_emoticons/default/confused24.gif) Aha........ I have an extra unattached ground and that would explain it. (IMG:style_emoticons/default/idea.gif) So where does the ground attach to the chainbox?? Thanks I think this is the only one close enough |
Lo-Fi Version | Time is now: 9th June 2024 - 07:18 PM |
