914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,197 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I was looking around on Ebay when I found a VDO seller. He had lots of new VDO 52mm gauges with the same style back as the 914 console gauges. I thought I would buy one to experiment with. So, the gauge showed up today and I went at it to remove ring and glass. I flipped it over and undid the nut and dropped the gauge out. Well that's when I knew it wasn't going to work looking a the inside of gauge. First up the new gauge is about 10mm taller and the back plate holes are larger. Long story short, 1 1/2 hours later I chalked it up to good information that I could pass along.
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 16th July 2025 - 04:06 PM |
