> using lighter for 12V inflator, any issues with using this?
914 RZ-1
post Sep 23 2015, 12:37 PM
Porsche Padawan
Are there any issues with using the cig lighter to power a 12V tire inflator? Some of the reviews of inflators mention blowing fuses, but these appear to refer to newer cars. Should the car engine be running when using the inflator? Anyone with any advice about using or not using this?
Replies(1 - 11)
Tom_T
post Sep 23 2015, 12:52 PM
TMI....
914s are 40 years old now & so are the wires & copper in them!
I've had an inflater blow fuses on our newer wires `88 Westy, as well as brand new rented trucks we use as tow vehicles. Both for little bike tires & big ole vehicle & trailer tires.
So I would advise against it, or at least get a far better quality than what the FLAPS, HF, HD, Lowes, etc. sell, cuz they get hot when running even a short time!
That causes even more friction, & that is what I think is causing more current draw & blowing fuses & electrical fires in some cases.
That's my 2 cents! (IMG:style_emoticons/default/beerchug.gif)
Tom
914 RZ-1
post Sep 23 2015, 01:04 PM
Porsche Padawan
QUOTE(Tom_T @ Sep 23 2015, 11:52 AM) *
Tom
Maybe I'll just use a hand pump!
porschetub
post Sep 23 2015, 01:40 PM
QUOTE(914 RZ-1 @ Sep 24 2015, 07:04 AM) *
Tom
Hand pump whats that (IMG:style_emoticons/default/rolleyes.gif) ,some of these compressors pull a lot of current,certainly more than the lighter I would extend the leads on your electric one and run straight on to the battery when you need it.
bandjoey
post Sep 23 2015, 01:47 PM
bandjoey
Cig lighter hole is larger than new plugs so contact is iffy and wires small. It was intended for 15 seconds of use. Get a HF battery booster / inflator about $40 and you good to go.
EdwardBlume
post Sep 23 2015, 01:52 PM
You can tap the battery directly. I used to use a chargeable one with good results.
Elliot Cannon
post Sep 23 2015, 04:10 PM
Group: Retired Members
I use a small SCUBA pony bottle for a compressed air source with the first stage of an old SCUBA regulator. The first stage reduces the pressure to a usable 120 PSI. The only drawback is, you must be SCUBA certified to have the tank re-filled and it must be visually inspected and pressure tested on a regular basis.
Valy
post Sep 23 2015, 06:45 PM
No problems using a cheap tire compressor on my Toyota. For the 914 I connect it straight to the battery cause the lighter cage is too big.
They like the engine running as the IR drop on the cables is big, and the last thing you want after a flat is a dead battery.
I like Elliot's idea. If you can't use a scuba tank, just buy the CO2 cartriges used by cyclists, like 200 of those (IMG:style_emoticons/default/smile.gif)
Now seriously, you can use a fire extinguisher tank.
porschetub
post Sep 24 2015, 01:40 AM
QUOTE(Elliot Cannon @ Sep 24 2015, 10:10 AM) *
oh,thats different,you don't have an air compressor (IMG:style_emoticons/default/confused24.gif)
EdwardBlume
post Sep 24 2015, 06:52 AM
SCUBA... you learn something new every day. (IMG:style_emoticons/default/aktion035.gif)
Elliot Cannon
post Sep 25 2015, 05:47 PM
Here's a nice 12 volt pump for pretty cheap. From Shanghai Tool Supply. http://www.harborfreight.com/12V-100-PSI-H...il_s1031_c3915c
914 RZ-1
post Sep 26 2015, 02:35 PM
Porsche Padawan
QUOTE(bandjoey @ Sep 23 2015, 12:47 PM) *
Like this one? It's $75 on sale: http://www.harborfreight.com/4-in-1-jump-s...ssor-62374.html
- Lo-Fi Version Time is now: 11th July 2025 - 08:25 AM
