Is this piece removable?, Backer for latch striker |
TargaToy |
Oct 3 2015, 08:21 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Replacing another chunk of my car and I'm doing some clean-up of the old seam sealer and undercoating before I start fitting the new metal. Does the backer for the door striker come off? It appears to be a single piece with 4 threaded tubes...and it looks like it may have been held in place by tape until the 4 machine screws were installed at the factory. But the joker is really fused in place. I don't want to pry too hard if it's spot welded.
ejm |
Oct 3 2015, 08:33 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Not welded, Needs to float so the striker plate can be adjusted. Early ones had a metal tab to retain them, later ones enclosed in a box.
TargaToy |
Oct 3 2015, 08:37 PM
Thanks a lot. It's a 72 so that must be the metal retaining strap I'm seeing.
Lo-Fi Version | Time is now: 8th June 2024 - 01:20 PM |
