Intake Runner Connecting Hose |
stinkindiesel |
Oct 6 2015, 02:59 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I understand the intake runner hoses that seal the intake runners to the distributor housing on a 1.7L are no longer available. That's PN 022 133 241 B. What are people doing as a replacement? Just find some heater or radiator hose that fits tight over the tubes?
Gary |
walterolin |
Oct 6 2015, 03:41 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Think the PN changed to 039133241. Google this number, several vendors including Pelican for 4.25 USD per.
Bob L. |
Oct 6 2015, 03:44 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Check this page ...
http://www.pelicanparts.com/cgi-bin/ksearc...039-133-241-M58 |
JawjaPorsche |
Oct 6 2015, 04:20 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Some are using 2.0 hose (which are bigger) and using water hose clamps for a good seal.
Dave_Darling |
Oct 6 2015, 04:21 PM
I believe those are the wrong diameter. The "039" part number makes me think that those are for the 2.0 motor, which uses larger-diameter intake runner pipes than the 1.7 does. (The 1.8 uses the same size as the 2.0 ones.)
You'll have to clamp those down quite a ways to make them fit, I believe. See if you can find radiator hose of the correct diameter, that's probably a better option. --DD |
McMark |
Oct 6 2015, 05:45 PM
stinkindiesel |
Oct 7 2015, 12:25 PM
Thanks, guys.
I actually have a set of the 1.8/2.0L hoses I ordered before I knew they weren't all the same. Guess I'll just take an intake runner down to the FLAPS and see if I can find something that fits. Gary |
Lo-Fi Version | Time is now: 1st June 2024 - 12:45 AM |
