how to plug and unplug electrical connector, electrical connector |
Highland |
Oct 8 2015, 08:08 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
dangrouche |
Oct 8 2015, 08:26 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
looks like push on spade on both sides; use needle nosed pliers and grab the base of the connector. Careful, usually brittle wire casing
fixer34 |
Oct 8 2015, 08:42 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
It's an inline dual spade connector-VW used them a lot. As previous post mentioned, you should be able to get the tips of needle-nose pliers into the opening by the wire and grab the metal part of the connector. Hold on to the plastic connector while pulling on the pliers. Try to pull straight out and not bend the wire too much.
cary |
Oct 8 2015, 09:54 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
What they said .............. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 05:24 AM |
