repair hole in engine tin? |
iankarr |
Oct 14 2015, 11:51 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hey guys,
Looks like the PO cut a hole the size of a nickel on the top of the passenger side tin, right above the oil cooler. I have no idea why. I plugged it up with some butyl putty, but would like to do a more permanent repair as part of my winter work. Any suggestions? Are the tins even weld-able? Thanks! |
budk |
Oct 15 2015, 05:04 AM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
Hey guys, Looks like the PO cut a hole the size of a nickel on the top of the passenger side tin, right above the oil cooler. I have no idea why. I plugged it up with some butyl putty, but would like to do a more permanent repair as part of my winter work. Any suggestions? Are the tins even weld-able? Thanks! It's metal so have at it..... (IMG:style_emoticons/default/welder.gif) |
maf914 |
Oct 15 2015, 06:57 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
iankarr |
Oct 15 2015, 08:39 AM
Thanks. I noticed that even just plugging that hole lowered my oil temps. Kinda amazing how small changes in the airflow have a big effect.
Lo-Fi Version | Time is now: 6th June 2024 - 08:47 AM |
