Exterior mounted below trunk Radiator, Iam sure its been tried..?? |
flmont |
Oct 17 2015, 11:17 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
When it comes to cooling,has anyone tried a exterior below the trunk mount,Iam curious ,if it would work,Ive never seen any discussion's about it...???? FM
Mike Bellis |
Oct 17 2015, 11:31 AM
There's no room under the front trunk and no air flow under the rear trunk.
913B |
Oct 17 2015, 11:50 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
SirAndy |
Oct 17 2015, 12:40 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There's no room under the front trunk and no air flow under the rear trunk. (IMG:style_emoticons/default/agree.gif) |
Mueller |
Oct 17 2015, 05:19 PM
Car has two trunks...which one are you talking about?
Surely not the front one, cause you'd rip that sucker off right away.... rear would be tough unless you had some custom ones made and then figured how to get air in and air out. |
r_towle |
Oct 17 2015, 05:26 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
In racing form, we used a 3*10 inch oil cooler strapped to the bottom of the engine bar with a little scoop under it to catch a bit more air.
Racing has no potholes like the street, so keep that in mind. It was plumbed with a sandwich plate at the filter and worked perfectly fine for that application. Others have put oil coolers next to the tranny, up high, with fans to draw in air and while I have never tried that, the people that have seem to still be using them, so they must do at least as much as the little one we used. Rich |
Lo-Fi Version | Time is now: 7th June 2024 - 07:51 AM |
