Early vs late trailing arms, Difference? |
mepstein |
Oct 19 2015, 02:50 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What say you guys
Also - Is there an early and late headlight bucket? |
914Sixer |
Oct 19 2015, 03:12 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early trailing arms had an extra tab on them to hold the hand brake cable out of the way. Seems like the tab disappeared before the 73 models came out. They used the same strap as the 911. That is about the time they added an extra piece of rubber around the brake cable to prevent wear where it goes over the motor bar. Tab was only on the drivers side. It was necessary on -6 because of the heat exchangers.
All headlight buckets should be the same. Only the pivots are different. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:34 AM |
