| Luke M |
Oct 23 2015, 12:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Well it's gotten to be that time finally. I've been collecting parts to do the repair on my 914-6 and now the work starts. The main issue is the hell hole/inner engine long, inner pass long, pass inner rocker panels are rusted out. The last part I was trying to source seams to be NLA. I sourced most of the parts from the good guys at Restoration Design. I received my order today for the last batch of things. Based on a few threads that I've looked over the outer shell to the inner engine long is currently not being made by RD. A few guys have made their own which looks like a real pain in the rear to do. I laid out all the new metal to see how things lined up. By the looks of things it will need some fine tuning to mate things properly. Before I start cutting into the chassis I'll build a few braces to keep things true.
Time for the pics... Attached image(s)
| stevegm |
Oct 23 2015, 02:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States
| wndsnd |
Oct 23 2015, 02:20 PM
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Is that the car that Kirk sold?
| Mueller |
Oct 23 2015, 02:36 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Good luck...I hope mine isn't as bad once I start digging into it!
| Cairo94507 |
Oct 23 2015, 03:05 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,771 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Excellent. It looks like you have matters well in hand. Keep the pictures coming. (IMG:style_emoticons/default/popcorn[1].gif)
| Luke M |
Oct 23 2015, 03:20 PM
| wndsnd |
Oct 23 2015, 03:31 PM
Big project for sure, but the fact that it is on a rotiserrie, should make it manageable. Measure twice, cut once. Enjoy.
| rick 918-S |
Oct 23 2015, 03:41 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,352 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Nice. (IMG:style_emoticons/default/popcorn[1].gif)
| Kansas 914 |
Oct 23 2015, 03:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
| Krieger |
Oct 23 2015, 05:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,882 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Yea!
| Luke M |
Feb 20 2018, 11:12 AM
Well after nearly three years of searching for a NOS right long I was able to source and buy one. Probably the last one in the US that's for sale ( watch now two will pop up for sale ). I should have it in my hands by late Weds and will post pics once it's here. So with that said, I have a few questions on how to tackle this job.
I know Kent replaced the drivers side of Jim's 6 seen here : http://www.914world.com/bbs2/index.php?sho...4443&st=100 I see Kent has made a jig to align things which I also made. If you see this Kent how did you attach the rear most section to the rear trunk/shock tower area? Did you weld from the inside as well as the outer portions? I plan to brace the living heck out of the chassis prior to cutting into it. Any area worth more bracing then others? I plan on checking the door gaps and all of the specs prior to/while welding in place. Stay tuned... |
| bbrock |
Feb 20 2018, 11:32 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Yeah Man! (IMG:style_emoticons/default/aktion035.gif) A lot of work, but also very satisfying. Looks like you've already got a handle on it, but brace the doors very well with an adjustable brace so you can adjust your gaps prior to and during welding. Once a long comes off, you'll be amazed how rubbery the car becomes, and also how easy it is to dial in the gaps precisely. I'm looking forward to watching this.
| rgalla9146 |
Feb 20 2018, 02:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,998 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Hey Luke Excellent ! Now's the time. Take it one day at a time. It'll get done. Be careful. Rory |
| bigkensteele |
Feb 20 2018, 05:30 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
Why did you decide not to use everything you pieced together above? (IMG:style_emoticons/default/confused24.gif) Looks like you had it well underway.
| Luke M |
Feb 20 2018, 07:16 PM
Why did you decide not to use everything you pieced together above? (IMG:style_emoticons/default/confused24.gif) Looks like you had it well underway. I wanted an NOS part for the repair to begin with. It's just hard to come by the pass side now a days. I found one and will be using it to make the repair. I will sell the other parts that I will not be using. |
| Luke M |
Feb 20 2018, 07:17 PM
| Luke M |
Feb 21 2018, 12:29 PM
Look what showed up today... (IMG:style_emoticons/default/piratenanner.gif)
I'll be removing the 4 cyl mount as this is going into a factory 6. I'll be posting it for sale once I remove it. The pics of this rare NOS item. Attached image(s)
| rhodyguy |
Feb 21 2018, 12:37 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
WOW! Platinum.
| mepstein |
Feb 21 2018, 12:38 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| David Billo |
Feb 21 2018, 04:34 PM
Member ![]() ![]() Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
Wow, did that come all welded together like that as one complete inner long, including the battery pylon?
Lo-Fi Version | Time is now: 5th October 2026 - 03:37 PM |
