> Ground location, Of factory console harness
Porschef
post Nov 1 2015, 11:56 AM
How you doin'
Don't want to add another wire if I don't have to; without pulling the whole thing apart, can someone direct me to where it ties in to the chassis?
Thanks.
Replies(1 - 8)
stugray
post Nov 1 2015, 12:05 PM
The main one is where the battery ties to the chassis right behind the battery to the inner fender wall.
Porschef
post Nov 1 2015, 01:22 PM
How you doin'
Thanks Stu, I'll check that out.
JeffBowlsby
post Nov 1 2015, 04:31 PM
914 Wiring Harnesses
The 914 has several ground points, in addition to the one at the battery.
The ground for the center console gauges is accessed at the connections on top of the center tunnel, which enters the main chassis harness, and is physically on the divers side firewall under the relay board.
r_towle
post Nov 1 2015, 04:36 PM
Custom Member
Relay board, underneath in engine bay
Fuse panel, inner fender well, need to drop the fuse box to see it
Battery, inner fender well behind firewall
Front lights are on the inner fenders up in the front trunk
I think there is one more common ground point under the front cowl for the heater/blower/ washer and wipers.
JeffBowlsby
post Nov 1 2015, 04:41 PM
r_towle
post Nov 1 2015, 04:47 PM
Custom Member
Even better.
scyon90
post Aug 29 2021, 12:09 PM
QUOTE(Jeff Bowlsby @ Nov 1 2015, 04:41 PM) *
Using this info years later, thanks Jeff !
StarBear
post Aug 29 2021, 07:16 PM
Ditto! (IMG:style_emoticons/default/agree.gif)
I even laminated a copy to keep in the car!
- Lo-Fi Version Time is now: 16th June 2024 - 09:56 PM
