> Key-in-ignition, Wired to the buzzer ?
jim_hoyland
post Nov 5 2015, 09:20 PM
Get that VIN ?
Was the ignition switch wired such that the warning buzzer would sound if the key was left in the ignition switch. The 911 ignition switches do for sure, how about a 914 ?
Replies(1 - 19)
zambezi
post Nov 5 2015, 10:05 PM
Yes, mine does....'73.
sb914
post Nov 5 2015, 10:07 PM
Surf Guru
QUOTE(jim_hoyland @ Nov 5 2015, 07:20 PM) *
My blue car does Jim 73
toolguy
post Nov 6 2015, 12:17 AM
Yes. . the 'buzzer' is what looks like a relay on the fuse tray under the dash. . except that this relay is red. . what makes the buzzing is the fact the relay is wired internally so it has a contact in the operate circuit so that as soon as it operated, the contact opens the path and the relay releases. . does this as fast as it can and causes a buzzing chatter.
If you don't like the buzzing, simply remove the relay. .
rgalla9146
post Nov 6 2015, 06:22 AM
QUOTE(toolguy @ Nov 6 2015, 01:17 AM) *
Isn't the buzzer a rectangular black one ?
jim_hoyland
post Nov 6 2015, 06:39 AM
Get that VIN ?
OK; Now, what wire goes from the ignition switch to the buzzer ? I'm trying to re-establish the connection(s)
I assume that the connection is a ground type: key-in maintains the ground to the buzzer; key-out breaks the ground connection and ends buzzing. So, I need the wire color code and or connector on the ignition switch it goes to.
CooltimesJr
post Nov 6 2015, 06:24 PM
got an ohm meter? i'm wondering if the two smaller male connectors are completed when the key is inserted into the cylinder. If I still had all of dad's old FSM's I could tell you right away. (IMG:style_emoticons/default/headbang.gif)
jim_hoyland
post Nov 6 2015, 06:45 PM
Get that VIN ?
QUOTE(CooltimesJr @ Nov 6 2015, 04:24 PM) *
I'll give those a try
jim_hoyland
post Nov 8 2015, 06:42 PM
Get that VIN ?
I had a change to do some testing on a switch that is out of the car. There are 3 large spade tetminals: 30, 50, 15, X; and there are two small spade connectors: P and S
P has continuity with 30 a disused for the parking light function when the TS lever is left on and ignition is off.
S would have continuity with 30 whenever the tip of the key is inserted, continuity was observed in all key positions including off; pull the key ou and it breaks continuity..
I'm still trying to figure out how this circuit might trigger key-in-ignition warning buzzer
Any ideas ? I thinking relay, but not sure how.....
jim_hoyland
post Jun 24 2025, 08:26 PM
Get that VIN ?
Still trying to figure this out….
Superhawk996
post Jun 24 2025, 08:38 PM
Wiring is different early vs late.
What year?
JeffBowlsby
post Jun 24 2025, 08:42 PM
The buzzer on a 74-76 car is internal to the seatbelt relay interlock box. Have you bypassed this interlock box?
Edit: SH beat me to it!
Superhawk996
post Jun 24 2025, 08:51 PM
QUOTE(JeffBowlsby @ Jun 24 2025, 10:42 PM) *
Would be awfully funny if we can help him get er’ operational based on the schematic and the write up on the interlock relay.
FWIW - I’ve been highly distracted. Was on a massive road trip and now having a septic system installed for the garage. When that’s done I’ll get back to finishing the write up on the relay box and hopefully fixing that in-op one. @JeffBowlsby @Bdstone914 @montreal914
JeffBowlsby
post Jun 24 2025, 09:11 PM
Thx for the update, I figgurd you may have been distracted. No worries. We appreciate your efforts on this mystery black box.
JeffBowlsby
post Jun 24 2025, 09:12 PM
I think it would be cool if it could be easily achieved, if the door buzzer and dash light could be preserved, but the troublesome ignition interlock function could be disabled.
jim_hoyland
post Jun 25 2025, 09:28 AM
Get that VIN ?
QUOTE(Superhawk996 @ Jun 24 2025, 07:38 PM) *
What year?
‘75
jim_hoyland
Get that VIN ?
QUOTE(JeffBowlsby @ Jun 24 2025, 07:42 PM) *
Yes
Root_Werks
post Jun 25 2025, 09:39 AM
Village Idiot
I used this wire to power the "on" for my radio. Radio is on whenever the key is on. On my 75' 914, thought the wire was solid grey? Maybe I can have a look and report back.
JeffBowlsby
post Jun 25 2025, 10:42 AM
Chassis harness schematic says its the grey/brown wire. Please verify.
Steve
post Jun 25 2025, 10:49 AM
Mine is also a 75. I bought a VW buzzer and was going to hook it up, but never got around to it. Future project with all my other future projects.
- Lo-Fi Version Time is now: 1st July 2025 - 06:02 AM
