CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
A while Back I got this NOS front european turn signal leans kit.
Now I want to do it properly, and convert the bulbs from one to two. I saw this Kit on AA (and I like to avoid AA as much as possible) and I wonder, if it is any good? Also it is out of stockā¦ (IMG:style_emoticons/default/dry.gif) Are there better options? ![]() ![]() |
HaraldD |
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-November 08 From: Germany Member No.: 9,781 Region Association: Germany ![]() ![]() |
sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Camp914.com has the kit .for $30
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
You can post a WTB ad, I'm sure some people (me included) have sets of that light kit they aren't going to use. We buy parts and change our minds as our project changes direction over the years.
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Spoke's LEDs is a good option too....
CG-914 |
Thanks for all the links and suggestions. I will be doing it at Christmas...
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,610 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
If Spoke makes them again that is the best. The kit like Camp and AA sells is marginal. I have a set I didn't use and would give it away free for shipping and that would be next to nothing...
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Martin Baker |
I just heard I sold my cars! ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California ![]() ![]() |
Attached image(s) ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,707 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
If Spoke makes them again that is the best. The kit like Camp and AA sells is marginal. I have a set I didn't use and would give it away free for shipping and that would be next to nothing... Correct these kits are disappointing,a poor fit into the stock housings,joins in the wiring that make them hard to run, I also found them not very bright and changed to larger lamps which was an improvement. Had I known I would have bought the metal housing ones on German ebay,they appear to be more like the originals (IMG:style_emoticons/default/confused24.gif) . |
CG-914 |
Hank914 |
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None ![]() |
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: ![]() ![]() ![]() ![]() I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! |
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
Wonder how much of a difference it would make if you wrapped the new sheet metal with foil?
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: ![]() ![]() ![]() ![]() I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! A compass ? Not included in a tool kit |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Model shops sell 'real' chrome paint for more shine
CG-914 |
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! It is a compass. I got it out of my dads architecture stuff, I'm sure he has it till the 70s... They are pretty bright right know, it is galvanised sheet matel so it reflects the light pretty good. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
If Spoke makes them again that is the best. I should have more front boards in Feb. We're making rear boards now. The board shown below turns off the running light when the turnsignal is active to provide more contrast so others will see the turnsignal better. Attached thumbnail(s) ![]() Attached image(s) ![]() |
SKL1 |
Spoke's boards are the easiest and best way to go. I've got both styles on my 914's. The euro style works great without that cheap plastic divider that's in the various kits.
Just need his rear boards for my '73- didn't order them in time on his last run. |
Lo-Fi Version | Time is now: 16th June 2024 - 05:43 PM |
