tazz9924 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None ![]() |
I have for sale 4 aluminum rims all in good condition. if they were buffed the would look great. missing one lug bolt and one has very slight rash. these are 15"x 4.5 they are light and a good upgrade! 300 picked up i will have to figure out shipping if interested. tires not included
Attached thumbnail(s) ![]() ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Offset?
Exact width would help with offset, that 1/2" could make or break a deal if someone has to modify their fenders. |
tazz9924 |
i will figure out offset and exact dimensions latter today
tazz9924 |
Update they are a 15" rim thats 4.5" wide with -29 offset hope that helps!
Mueller |
Update they are a 16.25" rim thats 6.25 wide with -29 offset hope that helps! Nope, you made it worse (IMG:style_emoticons/default/smile.gif) ..... you need to learn how to measure a rim! http://www.sl113.org/forums/uploaded/jeffc...rim%20width.jpg and for the diameter, just see what size tire, for example 195/60-15 should be on the tire...the last 2 digits is the wheel diameter. |
tazz9924 |
got final measurements (correct ones) earlier posts now reflect such and bump 300$
Lo-Fi Version | Time is now: 17th June 2024 - 06:17 AM |
