3pc Forged Alloy Wheels 15x8, 9 |
greggearhead |
Dec 4 2015, 11:24 AM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
EDIT - SOLD
These look a lot like Gotti's, but are made by Keizer. They are very lightweight - the 15x8's weigh LESS than 14lbs. These have been used as track wheels (and then on a stupid VW with stretched tires - not me), so have some issues, but not bad. Specs - 15x8 Fronts, 6 1/4" backspacing, ET/offset about 22-23mm 15x9 Rears , 6 1/4" backspacing, ET/offset about 12-13mm Three of the wheels have small cracks on the inner shells, at the very perimeter, not into the bead. They can be repaired easily enough, or completely new barrels can be had for $105 each. Happy to forward the contact info I have. I'm asking $700 for these, which still puts you way, way under new prices even with the new shells, or if you can have them repaired for less, you are that much better off. (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249865.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249866.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249866.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1449249866.10.jpg) |
greggearhead |
Dec 4 2015, 11:26 AM
greggearhead |
Dec 8 2015, 07:46 AM
Bump
greggearhead |
Dec 12 2015, 12:41 PM
I'm not a 914 expert, but yes, I would expect these would require flares, at the least in the rear for the 9s.
sixnotfour |
Dec 12 2015, 01:39 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
really would like to know where you can get the rim halves for those for 105 ??
greggearhead |
Dec 12 2015, 01:42 PM
From the manufacturer of the wheels. I spoke with them on the phone 2 weeks ago. No problem.
sixnotfour |
Dec 12 2015, 01:51 PM
wow thanks,that's reasonable, I have some I would like to make wider..I had no idea Thanks (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 01:29 AM |
