AAR, What does the lead connect to? |
jack20 |
Dec 6 2015, 03:49 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hello,
I just removed my AAR and the red lead wasn't connected. The end of the wire was severed (not at the base of the AAR but the terminal end) The spade connector is gone, presumably connected somewhere but I can't find the terminal. Can anybody point me in the right direction? Thank You, Jack |
pilothyer |
Dec 6 2015, 04:05 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Hello, I just removed my AAR and the red lead wasn't connected. The end of the wire was severed (not at the base of the AAR but the terminal end) The spade connector is gone, presumably connected somewhere but I can't find the terminal. Can anybody point me in the right direction? Thank You, Jack It should connect to the wire that goes to the 12 pin connector on the relay board pin 12 |
JeffBowlsby |
Dec 6 2015, 04:07 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It connects to the single white wire in the ignition harness, found in the vicinity of the AAR
jack20 |
Dec 6 2015, 04:27 PM
Fount it!
Thanks so much gents. Jack |
Lo-Fi Version | Time is now: 1st June 2024 - 07:51 PM |
